    Display mirror data sent over serial terminal.
    PRODUCTS
    6.3k
    • ajb2k3A
      ajb2k3
      Sorry all having a serious stupid moment here!
      How do I get
      m5.lcd.print();
      to show the data getting sent over the serial terminal?
      Following in my code.
      // Example for M5Stack StepMotor Module (I2C verison)
      // 2018/6/27 JimmyLai
      #include <M5Stack.h>
      #include <Wire.h>
      // put your setup code here, to run once:
      M5.begin();
      Wire.begin();
      Serial.begin(115200);
      m5.Lcd.setTextColor(WHITE, BLACK);
      m5.Lcd.setTextSize(2);
      m5.lcd.setBrightness(100);
      M5.Lcd.setCursor(4, 10);
      M5.Lcd.println("Press A to move turntable.");
      SendCommand(0x70, "G21");
      SendCommand(0x70, "$2=1"); //Sets the steps per mm on the Z axis to 1.
      void SendByte(byte addr, byte b) {
      Wire.beginTransmission(addr);
      Wire.write(b);
      Wire.endTransmission();
      void SendCommand(byte addr, char *c) {
      while ((*c) != 0) {
      Wire.write(*c);
      c++;
      Wire.write(0x0d);
      Wire.write(0x0a);
      if (digitalRead(39) == LOW) // A button
      while (digitalRead(39) == LOW) delay(1);
      SendCommand(0x70, "G1 Y6.4");
      SendCommand(0x70, "M2");
      // Get Data from Module.
      Wire.requestFrom(0x70, 1);
      if (Wire.available() > 0) {
      int u = Wire.read();
      if (u != 0) Serial.write(u);
      Wire.requestFrom(0x71, 1);
      delay(1);
      // Send Data to Module.
      while (Serial.available() > 0) {
      int inByte = Serial.read();
      SendByte(0x70, inByte);
      SendByte(0x71, inByte);
      RopR 1 Reply Last reply Reply Quote 0
      • RopR
        Rop @ajb2k3
        Hint: If you surround your code with three backticks on an empty line, it ends up looking like below, which is much more readable for everyone...
        #include <Wire.h>
          M5.begin();
          Wire.begin();
          Wire.write(b);
          while ((*c) != 0) {
            Wire.write(*c);
            c++;
          Wire.write(0x0d);
          Wire.write(0x0a);
          delay(1);
        • I wouldn't use if (digitalRead(39) == LOW) to read the button because m5.BtnA.wasPressed() has all the debounce and everything built-in.
        • If you want the text to scroll if more serial data comes in, you could use M5ez. Then you could just print to ez.canvas instead of to m5.lcd. The user manual in on the site, the part about printing to the canvas is here. M5ez also has easier display functions, button handling and much much more.
        • ajb2k3A
          ajb2k3
          Thanks I'm working off M5's demo code which is causing alot of head scratching
          Back tics?
          • RopR
            Rop @ajb2k3
            @ajb2k3 Back-tics are the ` single quote that is not ' but the one that on an english keyboard is ~ without shift.
            • ajb2k3A
              ajb2k3
              I always intended to use M5EZ for the front end but I have been concentrating on the back end code.
              Also need to work out a boot Splash style start screen.
              • ajb2k3A
                ajb2k3
                @rop 在
                My current issue is that because there is no
                serial.print();
                I cant issue
                m5.lcd.print();
                or
                ez.canvas.print();
                I'm seriously confused with this code.
