LoRaWAN UNIT 868MHz (ASR6501)
Dear all, I am trying to use this device for point to point LoRa communication. I am able to communicatie through serial2 and using AT commands. I have the AT command list. Could anyone be of any help for using this device for sending and receiving data. I dont mean the complex WLAN example that is given by M5Stack, just simple send and receive.
Help is appreciated in this. Regards from The Netherlands -
Thanks you, I have used these examples for the M5Stack LoRa Module.
However, the ASR6501 is a different chipset, so these AT commands won't work. I really hope the M5Stack picks op there software department for providing a good set of examples. Regards -
Hello @HappyUser
I thought the examples are for the LoRaWAN module with the same chipset as used in the unit, but I guess they are for the older (EOLed) LoRaWAN modules. Sorry about that.
Thanks
Felix -
maybe you could refer to this example
@m5stack Thank you, that seems like a more structured example. I wint give up to get it working. We have three options : 1] I just dont understand, 2] I just dont understand, 3] I am using the wrong settings. Ha Ha Ha
