    drawJpgFile / drawBmpFile
    FAQS
    4
    30
    139.0k
    • R
      Richard
      I use Visual Studio too.
      i have just tested your programm and i still have the problem.
      I think it's a hardware problem.
      I'm waiting for another device
      Thank you.
      C 1 Reply Last reply Reply Quote 0
      • C
        Calin @Richard
        @ajb2k3 在 drawJpgFile / drawBmpFile 中说:
        Is there a hardware limitation for this i.e. is there a card size limit and a formatting requirement?
        Is there a specific image limitation for the image?
        I think there is no limitation on card size.
        There might be a limitation on card read/write speed and that depend on the sdcard manufacturer and model.
        As i know, the cards formatted as FAT32 are preffered.
        @richard 在 drawJpgFile / drawBmpFile 中说:
        Thank you.
        That problem can be caused by the ILI9341 controller from the TFT.
        If that is the case, the only solution is a replacement.
        • R
          Richard
          I use a SD 4mo FAT32
          • R
            Richard
            and also
            I tested with a 32mo
            • ajb2k3A
              ajb2k3
              I have a 32gig Class 10 sdhc formatted as fat32 MBT.
              How do I tell if I have the ILI9341?
              • C
                Calin @ajb2k3
                @ajb2k3 ILI9341 is the LCD driver used by the M5Stack TFT display: https://cdn-shop.adafruit.com/datasheets/ILI9341.pdf
                • ajb2k3A
                  ajb2k3
                  Ok, failed to get it to work with the jpgdraw script but if I convert to array it works, But!!!!!!
                  I had to reduce the image to a 256bit Indexed image!
                  • R
                    Richard
                    I tested my programm and my file jpg (sd 4go) with IDE Arduino 1.8.5 on another M5Stack .
                    It works very well.
                    The first M5stack doesn't work propely.
                    I hope the M5stack store will change it.
                    • R
                      Richard
                      • R
                        Richard
                        Thank you Calin!
