Micropython - SHT30 in BTC Base
  • If someone would try work with SHT30, I recommend:
    https://github.com/rsc1975/micropython-sht30
    but in this base you should propertly sel scl, sda pins and i2c addres SHT30 is 0x44.
    Code:
    from sht30 import SHT30
    sht30_sensor = SHT30(scl_pin=22, sda_pin=21, delta_temp=-3, i2c_address=0x44)
    temperature, humidity = sht30_sensor.measure()
    Also what i noticed that is showed temperature is higher than real. To correct it i use delta_temp.
  • It is a bit too early because MicroPython is still not there on M5Paper that I own, but as it uses the same SHT30, I also noticed some delta issue in temperature using Arduino.
    Is it a common thing with this component ?
  • I honestly don't understand M5Stack's way of working. There is this ENV2 with python support: https://docs.m5stack.com/#/en/unit/envII it has a SHT30, but then you spend $80 on a M5Paper and you don't get python support for the SHT30. How hard is it to put in the the right lib.
    I know I can do it myself, but M5stack should have done this already :-/
  • @sj3fk3 said in Micropython - SHT30 in BTC Base:
    Micropython on the M5Paper is in early alpha because we pushed M5Stack to get it out before the holiday. I spent yesterday doing some testing and I cannot get any SHT30 devices to work no matter if its the internal SHT30 on the paper or the env2 unit.
    What lib are you using as I cant even get raw reg read and writes to work.
  • @kedulowt said in Micropython - SHT30 in BTC Base:
    I can't get this to work
      File "sht30.py", line 40, in __init__
    NameError: name 'I2C' isn't defined
  • Vielleicht hilft euch das weiter. Läuft auf einem M5Stick-C
    main.py
    import unit
    import machine
    import array
    import sht31
    from machine import I2C, Pin
    i2c = I2C(freq=100000, scl=Pin(32), sda=Pin(33) )
    sensor = sht31.SHT31(i2c, addr=0x44)
    while True:
    #Sensor SHT31-----------------------------------------------------------
    temp_humi = sensor.get_temp_humi()
    wait_ms(600)
    Temperatur = round(temp_humi[0],2)
    Feuchte = round(temp_humi[1],2)
    sht31.py
    import time
    R_HIGH = const(1)
    R_MEDIUM = const(2)
    R_LOW = const(3)
    class SHT31(object):
    Diese Klasse implementiert eine Schnittstelle zur SHT31 Temperatur und Luftfeuchtigkeit.
    Sensor von Sensirion.
    # Diese statische Karte hilft, den Heap und die Programmlogik sauber zu halten.
    _map_cs_r = {
    True: {
    R_HIGH : b'\x2c\x06',
    R_MEDIUM : b'\x2c\x0d',
    R_LOW: b'\x2c\x10'
    False: {
    R_HIGH : b'\x24\x00',
    R_MEDIUM : b'\x24\x0b',
    R_LOW: b'\x24\x16'
    def __init__(self, i2c, addr=0x44):
        Initialisiert ein Sensorobjekt auf dem angegebenen I2C-Bus, auf das von der
        angegebene Adresse.
        if i2c == None or i2c.__class__ != I2C:
            raise ValueError('I2C-Objekt als Argument benötigt!')
        self._i2c = i2c
        self._addr = addr
    def _send(self, buf):
        Sendet das angegebene Pufferobjekt über I2C an den Sensor.
        self._i2c.writeto(self._addr, buf)
    def _recv(self, count):
        Lesen von Bytes vom Sensor über I2C. Die Anzahl der Bytes kann angegeben werden.
        als Argument.
        Liefert ein Bytearray für das Ergebnis.
        return self._i2c.readfrom(self._addr, count)
    def _raw_temp_humi(self, r=R_HIGH, cs=True):
        Lesen Sie die Rohtemperatur und Luftfeuchtigkeit vom Sensor ab und überspringen Sie CRC. Überprüfung.
        Liefert ein Tupel für beide Werte in dieser Reihenfolge.
        if r not in (R_HIGH, R_MEDIUM, R_LOW):
            raise ValueError('Falscher Wiederholbarkeitswert angegeben!')
        self._send(self._map_cs_r[cs][r])
        time.sleep_ms(50)
        raw = self._recv(6)
        return (raw[0] << 8) + raw[1], (raw[3] << 8) + raw[4]
    def get_temp_humi(self, resolution=R_HIGH, clock_stretch=True, celsius=True):
        Lesen Sie die Temperatur in Grad Celsius oder Fahrenheit und relativ dazu ab.
        Feuchtigkeit. Auflösung und Taktverlängerung können festgelegt werden.
        t, h = self._raw_temp_humi(resolution, clock_stretch)
        if celsius:
            temp = -45 + (175 * (t / 65535.0))
        else:
            temp = -49 + (315 * (t / 65535.0))
        return temp, 100 * (h / 65535.0)
  • @ajb2k3 said in Micropython - SHT30 in BTC Base:
    For now I have abandoned micro python and switched to (yuck) C and platformio.
