    M5Stack does not connect WiFi with Node attached
    6 Posts 4 Posters 11.9k Views 1 Watching
      pa7lim
      My M5Stack does not connect to WiFi when the Node shield is attached. When I remove the Node and connect the battery or USB shield, the WiFi connection is perfect.
      I have two M5Stack's and two Node's both same issue.
      Does anyone knows how to solve this?
      • E Offline
        ecasti
        Just received and similar issue here, from my desk there is no way to connect to WiFi, it work only closer to the router, it seem the node board interfere with antenna.
        • E Offline
          ecasti
          btw if i put in between a proto-modul ( still empty ) work perfectly fine, and maybe should help also getting better measure on DHT12, will try
          • m5stackM Online
            maybe is the router signal quality problem. you could try put the device closer the router
            • E Offline
              ecasti @m5stack
              @m5stack said in M5Stack does not connect WiFi with Node attached:
              No, i experience significative degradation with node base attached, while using face base i can connect from long distance. As i mentioned, putting proto board in between mitigate partially, i can gain some meter but not as using face base
              • L Offline
                Lewis-H Banned
                Installing the silabs Silicon Labs VCP Driver.pkg worked for me also. 👍
                (on OS X 10.11.6)
                Seems obvious that we need the drivers, but I thought I already had them after going thru the espressif/arduino-esp32 install steps.
                e.g. My "System Report / Hardware / USB" showed
                CP2102 USB to UART Bridge Controller driver
                For others' future reference, you should see something like:
                n8s-iMac:nleon$ ls -al /dev/tty.*
                crw-rw-rw- 1 root wheel 18, 2 Jul 4 11:14 /dev/tty.SLAB_USBtoUART
                Regardless, thanks for the pointer!
                Admin
                Apps4Rent
