    UIFlow 1.5.3
    Official Updates
    11.7k
    • m5stackM
      Ver 1.5.3. time : 2020.05.29
      UpdateLog:
      web:
      • Add Echo STT.
      • Add some blocks.3
      • Add StickC support in beta version.4: Fixed bugs.
      firmware:
      • Fixed: imu data error
      • Fixed: UI Background color error
      • Fixed: Button maximum recursive error
      • Fixed: DAC waveform not support error
      • update: PWM add set hold us method
      • Add: StickC device support
      • Add: unicode support (core 24px, StickC 16px)
      • Add: Echo STT support
      Echo STT
      • J
        Jan_Osch
        Great to get the update to 1.5.3.
        Two questions:
        • When will SD cards be supported in UIFlow 1.5.X for the M5Core?
        • Where do I get an Echo Speech token?
        And: isn`t UI this Flow based on micropython 1.12
        M5Burner 2.1.0 states "Base micropython v1.11" for UIFlow 1.5.3
        • m5stackM
          m5stack @Jan_Osch
          @jan_osch
          SD card function has been added, pls try to refresh the page.
          our engineer said. for the time being , UIFlow firmware base mpy 1.11
          the Echo Speech use tutorial pls wait. we will update the product docs as soon as possible.
          • J
            Jan_Osch
            Thank you
            • J
              jhfoo
              Echo support! Exciting! When is it GA?
              • m5stackM
                @jhfoo GA? your mean "google assistant"? for the time being, we don't have plan to connect it.
                • J
                  jhfoo @m5stack
                  @m5stack By GA I mean Generally Available. As in out of beta, ready for production use.
