    UIFlow 1.5.2
    28 Posts 9 Posters 108.2k Views 2 Watching
      jpilarski
      @m5stack
      Here is a quick example
      This code doesn't ever connect to blynk. Here is the code it generates:
      from m5stack import *
      from m5ui import *
      from uiflow import *
      from ble import blynk
      setScreenColor(0x222222)
      label0 = M5TextBox(52, 10, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
      label1 = M5TextBox(46, 49, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
      circle0 = M5Circle(141, 122, 15, 0xFFFFFF, 0xFFFFFF)
      val = None
      message = None
      blynk.init('fire', 'xxx', blynk.BLE)
      while True:
        circle0.setSize(val)
        wait_ms(2)
      @blynk.handle_event('connected')
      def blynk_write():
        global val, message
        rgb.setColorAll(0xff0000)
        pass
      @blynk.handle_event('write v2')
      def blynk_write(*args):
        global val, message
        val, message = args[0], args[1]
        label0.setText(str(val))
        label1.setText(str(message))
        pass
      Here is the manually adjusted code that connects with blynk.
      from m5ui import *
      val = None
      message = None
      def blynk_write():
        global val, message
        pass
        global val, message
        pass
      while True:
        wait_ms(2)
      In the example above when the message variable is shown using label1.setText(str(message)) it shows the following ['255']. What is the most effective way in micropython to remove the [] and ' ' and convert message variable to an integer. I am using
      which outputs this
        global val, message
        message = str(message.replace("'", '').replace(']', '').replace('[', ''))
        circle0.setSize(int(message))
        pass
      but should generate this
        global val, message
        message = str(message).replace("'", '').replace(']', '').replace('[', '')
        pass
        robalstona @jpilarski
        @jpilarski Some time ago I did custom blocks for blynk. They use rest api requests for communication, so they are not as advanced as those from uiflow. maybe these will work for you. I tested them on m5stickC and works.
        https://github.com/stonatm/UiFlow-custom-blocks/blob/master/blynk/README.md
          jpilarski
          @robalstona @m5stack Thanks for that suggestion. I'll try the blocks you developed out on StickC. The new ble blynk blocks work it"s just they require a little tinkering with the micropython code to get them connected. At least that is my experience of using them. I am still very happy to see them included in the latest beta version of uiflow. Also I look forward to seeing a screen_shot showing all the blocks operating together in a single setup because I might be setting them up in a way that introduces the minor issues I've come across.
          • m5stackM Online
            m5stack @jpilarski
            @jpilarski ok, the problem is clear. thank you feedback, we will fix this bug ASAP.
              jpilarski
              @m5stack
              Very cool. Thanks and it's really great to see bluetooth in micropython and uiflow. At one time you mentioned the micropython firmwares would be open source and made available on github, I know you have a uiflow micropython repo https://github.com/m5stack/UIFlow-Code but it doesn't always get updated with new releases, it would be great to see the repo get updated and have branches for each major release. I think so much great development can happen if the code is made available.
              • m5stackM Online
                m5stack @jpilarski
                @jpilarski You can talk about which lib your users want to open source.
                  Thrasher @m5stack
                  @m5stack
                  Can we have document with something like:
                  UIFlow lib
                  --API
                  --Methods
                  --Method example / construction
                  The way Arduino document its built-in libraries or similar to this?
                  Thank you
                  • m5stackM Online
                    m5stack @Thrasher
                    @thrasher
                    we had open source part UIFlow lib code. in this github :https://github.com/m5stack/UIFlow-Code
                    Taking into account some lib data security issues, we will not open source all libs for the time being, so you can talk about which libs users want, we will consider if open source these lib.
                      Thrasher @m5stack
                      @m5stack
                      I don't need source code.
                      I'd like documentation on API usage
                      E.g. LCD
                      -Lcd.print(text, posx, posy, size) - prints a text string
                      Etc.
                      Im not looking for any source code
                      Here's example from arduino:
                      https://www.arduino.cc/en/reference/libraries
                      And detailed info on functions:
                      https://www.arduino.cc/en/Reference/SD
                      No source code there but all functions detailed and explained how to use
                      Because blockly, Im sorry, is just lame
                        Sorry, I have been busy and suffering depression which resulted in my book getting neglected.
                          jhfoo @ajb2k3
                          @ajb2k3 Take care boss. Slow down and enjoy the earl grey.
                          Also: don't.do.anything.stupid. :D
