    Maximum recursion depth?
    Micropython
    6
    11
    14.7k
    • D
      dclaar
      I am getting:
        File "flowlib/hw/mpu6050.py", line 145, in acceleration
      RuntimeError: maximum recursion depth exceeded
      I'm using the timer and button events, and that may contribute, but how do I debug this? What is the maximum recursion depth, and can I display the current depth?
      • D
        dclaar
        Sometimes I get a stack dump almost immediately on starting the network, so maybe I'm skating close to the edge.
        Connected. Network config: ('192.168.6.109', '255.255.255.0', '192.168.6.1', '192.168.6.1')
        ***ERROR*** A stack overflow in task mp_thread has been detected.
        abort() was called at PC 0x400899a8 on core 1
        ELF file SHA256: 0000000000000000000000000000000000000000000000000000000000000000
        Backtrace: 0x400896a7:0x3ffb9160 0x40089991:0x3ffb9180 0x400899a8:0x3ffb91a0 0x4009220a:0x3ffb91c0 0x40093f98:0x3ffb91e0 0x40093f4e:0x3ffb91cc
        • m5stackM
          could you provide your code?
          • D
            dclaar
            • D
              dclaar
              I decided to go to a polling loop instead and it seems to work a lot better.
              • C
                crami25
                @dclaar
                See https://www.geeksforgeeks.org/python-handling-recursion-limit/ :
                by default, the value normally is 10^4.
                • D
                  dclaar
                  As I'm not doing recursion explicitly, there must be something going on behind the scenes. Or I've got an error! Or maybe event-driven isn't clean and somehow keeps calling itself.
                    SAbadshah
                    Since I'm not expressly using recursion, something else must be happening. Or I made a mistake! Or perhaps event-driven isn't clean and keeps naming itself in some way[url=https://mybankinginformation.com/citibank-routing-number/].[/url]
                      SAbadshah @SAbadshah
                      Instead, I choose to switch to a polling loop, and it seems to function much better.
                      • K
                        KirkSutton23
                        Instead, I switched to a polling loop, which seemed to work much better.
                        • teastainT
                          teastain @KirkSutton23
                          Rather, I chose to switch to polling, which worked much better, so it seems.
