    Speed up GPS data update
    Modules
    6
    10.5k
      SamSoul
      Hi all,
      I would like to know if it is posdsible to get 10Hz refresh rate of the data with the GPS module stackable ?
      By default it is only 1Hz.
      Thanks.
      • m5stackM
        you can use this software to setup . you can google able to find the refer tutorial.
        software link: https://www.u-blox.com/en/product/u-center
        • E
          ekalfwonS
          @m5stack can you be more specific? What software are you referring to? The Windows software linked to on the GPS module page (https://www.u-blox.com/en/product/u-center-windows)? Can that software talk to the GPS to update it through the USB connection to the M5Stack while it's connected?
          • m5stackM
            m5stack @ekalfwonS
            @ekalfwons you could connect to the M5Core then stack the GPS module(Need to configure transparent transmission) or just connect to the GPS module by USB to TTL convertor.
            • E
              ekalfwonS @m5stack
              @m5stack It would be good if there was some documentation explaining how to use the M5Stack to do the transparent transmission. Could that be added to the GPS Module product page, or linked from it? Right now there's a link to the software but no indication how one would use it with the GPS module.
              • O
                osioli
                @ekalfwons : Hi, I'm struggeling now at the same point. Do you have a solution after that time now?
                Cheers,
                Olaf
