    Looking for the Base Firmware for Unit-V
    Units
    5
    8.9k
    • K
      kylebuttress
      I'm looking for the Base Firmware for Unit-V, I was experimenting and have made a mistake with the unit-v and would like to know where I can get the base firmware so I can reflash to its default.
        http://community.m5stack.com/topic/1872/m5stickv-firmware_v5-1-1_beta
        • K
          kylebuttress
          Is there a correct way to flash the firmware using esptool i'm using esptool.py --chip esp32 --port /dev/tty.SLAB_USBtoUART --baud 115200 write_flash -z 0x1000 M5StickV_Firmware_v5.1.1_beta.kfpkg becuase even though it seems to flash I cannot connect with Maixpy i'm getting the following Connect fail, board ide mode no ack
          Any tips would be appreciated.
          thanks Kyle
          • T
            Thrasher
            Esptool can't flash it, its not an esp chip
            You need stickV burner from guides section
            https://docs.m5stack.com/#/en/core/m5stickv
            EasyLoader is
            • m5stackM
              the M5StickV/UnitV burn firmware tutorial
              https://docs.m5stack.com/#/en/quick_start/m5stickv/m5stickv_quick_start
