    Support for node
    6 Posts 2 Posters 11.1k Views 1 Watching
    • E Offline
      ecasti
      Hi all,
      just received a node bases and i was wondering if there is some plan tu support that bases on UIFlow.
      I tried without any luck to use:
      • RGB : supported only 10 of 12 leds
      • DHT12: env unit can't work because require also BMP280 or fail )
      • IR: Can't use as unit because mapped on different pins
        Of course i don't expect to use WM8978 via UIFlow, but at least the most common components mentioned above
      • m5stackM Online
        the RGB control : you can add a RGB LED Unit function.
        then change the pin seting and RGB total number like below:
        neopixel0 = unit.get (unit.NEOPIXEL, (Signal_pin,), LED_total_numbe)
        the DHT12: you can use the I2C function, to read the seosor data, in the UIflow navigation demo option already provide example.
        the IR control : you can add a IR Unit function. then change the pin seting like below:
        ir1 = unit.get(unit.IR, (Trasmiter_pin, receive_pin))
        • E Offline
          ecasti
          thanks, is clear.
          Only one question|:
          Which demo you refer to?
          • m5stackM Online
            m5stack @ecasti
            @ecasti the DHT12 demo:
            替代文字
            • E Offline
              ecasti
              @m5stack said in Support for node:
              DHT12
              I'm using Desktop version and not all demos are there,
              anyway i found that on the online version,
              thanks a lot
              • m5stackM Online
                m5stack @ecasti
                @ecasti ok. the desktop IDE will update the demo program in next version
