    M5StickC/ATOM on MacOS Catalina can't upload/ ESP32: Timed out waiting for packet header solution (Solved)
    44 Posts 19 Posters 272.9k Views 6 Watching
      cepics
      where is the G0 on M5Atom LITE??
      • m5stackM Offline
        m5stack @cepics
        @cepics Why do you want to upgrade ... 10.12 can support the ATOM. This upgrade tool is for those systems that don't recognize the port such as MacOS Catalina
          cepics
          I have problems to upload code on M5StickC and M5Atom LITE.....
          no serial port available in tools/port menu..
          I have also burn with easyloader (on a win machine) to reset the modules
          osx 10.12.5
          arduino IDE 1.8.9
          • m5stackM Offline
            m5stack @cepics
            @cepics you could try setup the baud to 115200. then try again. or contact our store. we will help you solve it. as soon as possible
              HerrLehmann @m5stack
              @m5stack
              I'm on macos 10.15.3 and I'm asking myself too, where is G0 on the M5Atom Matrix? Although I was able to apply the described firmware, I'm not able to connect via UIFlow IDE nor Arduino IDE (1.8.9).
              By the way: almost no image gets displayed on Safari from the documentation — neither iPad nor mac.
              • m5stackM Offline
                m5stack @HerrLehmann
                @herrlehmann M5Atom Matrix have not provided G0 Pin to outside. so the solustion 1 is for m5stickC. and could you use windows os test it again? maybe is the driver software problem .
                  cepics @m5stack
                  @m5stack said in M5StickC and ATOM on MacOS Catalina can't upload programs solustion:
                  no way!!! Atom serial port doesn't appear in the serial port list..... more than one cable tested....
                    @m5stack
                    No, the is (un)fortunately no Windows machine. I'm a little confused about the fact, that the above mentioned firmware is running without any problem. So there needs to be a connection between mac to m5atom in some way — or how is it writing to the device?
                      RschDev
                      My new m5stick-C are showing up on the MacOS (10.15.3) as M5 Serial Converter, and in the Arduino IDE (latest edition). I have applied the updater as suggested in this thread, and still get this response when trying to upload from the IDE to the device: "fork/exec /Applications/Arduino 2.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags: bad CPU type in executable
                      Error compiling for board M5Stick-C."
                      • m5stackM Offline
                        m5stack @RschDev
                        @rschdev clearly. this is a compiling error . you should check the error information , and check you program.
                        • m5stackM Offline
                          @herrlehmann did you installed the FTDI driver? you could try delete both below files. then connect your device try again.
                          /Library/Extensions/FTDIUSBSerialDriver.kext
                          /Library/Extensions/FTDIKext.kext
                          H 2 Replies Last reply Reply Quote 0
                            I had access to a Windows machine and was able to use the easy loader on my M5Atom Matrix. It is working on Windows.
                            For my mac:
                            Yes, I installed the FTDI driver, but they did not work. I've removed them as suggested, but it didn't change anything. There is still no device appearing in /dev/, so it is not accessible.
                              @m5stack did you dig any deeper into this? I'm still unable to use the M5Atom Matrix on my mac with Catalina. I started over again by installing and deinstalling stuff, but no new device appears. The system recognizes the M5Atom Matrix by naming a M5 Serial Converter with following information:
                              Produkt-ID: 0x6001
                              Hersteller-ID: 0x0403 (Future Technology Devices International Limited)
                              Version: 4.00
                              Seriennummer: 79525701B4
                              Geschwindigkeit: Bis zu 12 MBit/s
                              Hersteller: M5STACK Inc.
                              Standort-ID: 0x14500000 / 6
                              Verfügbare Stromstärke (mA): 500
                              Erforderliche Stromstärke (mA): 100
                              Zusätzlicher Betriebsstrom (mA): 0
                              I also applied the firmware update many times successfully.
                              @m5stack : Any other ideas? I'd like to play with it.
                              • m5stackM Offline
                                @herrlehmann did you have try to install the FTDI driver : https://www.ftdichip.com/Drivers/VCP.htm
                                  Pumpui @nsfilho
                                  @nsfilho don't update to 10.15.04....
                                    @m5stack : Yes, I did. By further investigating the driver, it looks like they are not working due to signing issues. I found this thread https://www.ftdicommunity.com/index.php?topic=409.msg1171#msg1171
                                    I'm waiting on this rerelease, than I'll let you know. Thanks.
                                      climbingrose
                                      I'm trying to apply firmware update on Catalina and having this error message:
                                      Detecting M5Stack products.
                                      Find M5Stack products.
                                      Kernel driver deteched.
                                      Apply magic success.
                                      Fail to cast magic stage 2, please contact vendor
                                      Wating for device in DFU mode..................................
                                      Any idea?
                                      R F 2 Replies Last reply Reply Quote 2
                                        Re4DeR @climbingrose
                                        @climbingrose I have same problem. Have you found any solution?
                                          Finnsen @climbingrose
                                          @climbingrose I have that same problem as well. It would be nice if @m5stack could support their products in a better manner and give us a good receipt to fix the issues.
                                          • m5stackM Offline
                                            m5stack @Finnsen
                                            @finnsen if you try these solution still can't solve the problem. you could contact the store
