    Get contents of a webpage in UIFlow
    UIFlow
    4.8k
    • J
      jmkhello
      I'm trying to use the HTTP library but every single time I try to use the library I get status 200 (meaning it worked) but then when I try to use the output variable I get a "ENOMEM" error which I am assuming is "error no memory"
      • lukasmaximusL
        Hi @jmkhello what kind of data are you trying to get from the webpage. This subject
        has been discussed in other forum posts, check these out and you may find your answer
        http://forum.m5stack.com/topic/1391/http-request-to-netatmo-fails-with-error-solved
        http://forum.m5stack.com/topic/1345/uiflow-http-request/3
        http://forum.m5stack.com/topic/1357/http-block-gives-error
        • E
          Efried
          I get this error in operation after a while using urequest in micropython. My impression is that it occurs less frequent when having shorter time intervals between the calls.
          I'm using uiflow 1.4.3 for M5Stack and the upload works but the program never starts, I have to use RUN.
