    Distance Visualization With Multiple SPAD areas in VL53L1X Time-of-Flight sensor
    PROJECTS
    10.8k
    • KabronK
      Kabron
      This example illustrates how to get information from multiple SPAD areas from VL53L1X TOF sensor. 16 Regions Of Interest(ROI) with size of 4 * 4 SPAD elements each are defined in SPAD sensor array. Thus, a 4 * 4 measurement matrix formed. Distances measured from each of 16 ROI, interpolated to 8 * 8 image and displayed as Thermal like image.
      Code here:
      https://yadi.sk/d/qpxO0fMItW4Qpw
      Video here:
      https://youtu.be/b18ghRCWawo
        sheepDog
        • C
          cepics
          hi, wich ino file I have to upload to visualize "thermal distance?
          SPAD_read doesn't compile with this output:
          Arduino: 1.8.9 (Mac OS X), Board: "M5Stack-Core-ESP32, QIO, 80MHz, Default, 921600, None"
          sketch/SPAD_read.ino.cpp.o:(.literal._Z8checkDevP12VL53L1_Dev_t+0x8): undefined reference to `VL53L1_RdWord'
          sketch/SPAD_read.ino.cpp.o:(.literal._Z5setupv+0x48): undefined reference to `VL53L1_WaitDeviceBooted'
          sketch/SPAD_read.ino.cpp.o:(.literal._Z5setupv+0x4c): undefined reference to `VL53L1_DataInit'
          sketch/SPAD_read.ino.cpp.o:(.literal._Z5setupv+0x50): undefined reference to `VL53L1_StaticInit'
          sketch/SPAD_read.ino.cpp.o:(.literal._Z5setupv+0x54): undefined reference to `VL53L1_SetDistanceMode'
          sketch/SPAD_read.ino.cpp.o:(.literal._Z5setupv+0x58): undefined reference to `VL53L1_SetMeasurementTimingBudgetMicroSeconds'
          sketch/SPAD_read.ino.cpp.o:(.literal._Z5setupv+0x5c): undefined reference to `VL53L1_SetInterMeasurementPeriodMilliSeconds'
          sketch/SPAD_read.ino.cpp.o:(.literal._Z5setupv+0x60): undefined reference to `VL53L1_StartMeasurement'
          sketch/SPAD_read.ino.cpp.o:(.literal._Z4loopv+0xc): undefined reference to `VL53L1_SetUserROI'
          sketch/SPAD_read.ino.cpp.o:(.literal._Z4loopv+0x10): undefined reference to `VL53L1_WaitMeasurementDataReady'
          sketch/SPAD_read.ino.cpp.o:(.literal._Z4loopv+0x14): undefined reference to `VL53L1_GetRangingMeasurementData'
          sketch/SPAD_read.ino.cpp.o:(.literal._Z4loopv+0x18): undefined reference to `VL53L1_clear_interrupt_and_enable_next_range'
          sketch/SPAD_read.ino.cpp.o: In function `checkDev(VL53L1_Dev_t*)':
          Multiple libraries were found for "SPI.h"
           Used: /Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/libraries/SPI
           Not used: /Documents/Arduino/libraries/SPI
          /var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/arduino_modified_sketch_71183/SPAD_read.ino:170: undefined reference to `VL53L1_RdWord'
           Used: /Users/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/libraries/SD
           Not used: /Users/Documents/Arduino/libraries/SD
          sketch/SPAD_read.ino.cpp.o: In function `setup()':
           Not used: /private/var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/AppTranslocation/65325227-2EA8-4077-950D-C93B6E24B2C5/d/Arduino-1.8.9.app/Contents/Java/libraries/SD
          Multiple libraries were found for "WiFiClient.h"
           Used: /Users/Library/Arduino15/packages/esp32/hardware/esp32/1.0.2/libraries/WiFi
           Not used: /private/var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/AppTranslocation/65325227-2EA8-4077-950D-C93B6E24B2C5/d/Arduino-1.8.9.app/Contents/Java/libraries/WiFi
          /var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/arduino_modified_sketch_71183/SPAD_read.ino:170: undefined reference to `VL53L1_WaitDeviceBooted'
          /var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/arduino_modified_sketch_71183/SPAD_read.ino:170: undefined reference to `VL53L1_DataInit'
          /var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/arduino_modified_sketch_71183/SPAD_read.ino:170: undefined reference to `VL53L1_StaticInit'
          /var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/arduino_modified_sketch_71183/SPAD_read.ino:170: undefined reference to `VL53L1_SetDistanceMode'
          /var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/arduino_modified_sketch_71183/SPAD_read.ino:170: undefined reference to `VL53L1_SetMeasurementTimingBudgetMicroSeconds'
          /var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/arduino_modified_sketch_71183/SPAD_read.ino:170: undefined reference to `VL53L1_SetInterMeasurementPeriodMilliSeconds'
          /var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/arduino_modified_sketch_71183/SPAD_read.ino:170: undefined reference to `VL53L1_StartMeasurement'
          sketch/SPAD_read.ino.cpp.o: In function `loop()':
          /var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/arduino_modified_sketch_71183/SPAD_read.ino:137: undefined reference to `VL53L1_SetUserROI'
          /var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/arduino_modified_sketch_71183/SPAD_read.ino:139: undefined reference to `VL53L1_WaitMeasurementDataReady'
          /var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/arduino_modified_sketch_71183/SPAD_read.ino:140: undefined reference to `VL53L1_GetRangingMeasurementData'
          /var/folders/f3/0kf10ljj6sj4q4twsw_vtxrw0000gn/T/arduino_modified_sketch_71183/SPAD_read.ino:141: undefined reference to `VL53L1_clear_interrupt_and_enable_next_range'
          collect2: error: ld returned 1 exit status
          exit status 1
