馃Have you ever tried Chat.M5Stack.com before asking??馃槑
    the tolerance of sh200q of StickC?
    5 Posts 3 Posters 12.5k Views 1 Watching
    • Z Offline
      zhufu86
      I'm curious about the tolerance of the sh200q acceleration readings of StickC.
      I put the StickC on the desk and make sure it will not be moved and be steady.
      Then I tried the codes below but got the acceleration higher than "1g". Why is that?
      >>> from hardware import sh200q
      >>> import math
      >>> imu = sh200q.Sh200q()
      >>> for i in range(5):
      ...     print((imu.acceleration[0],imu.acceleration[1],imu.acceleration[2]))
      ...     wait(1)
      (0.138, 0.058, 1.107)
      (0.14, 0.055, 1.111)
      (0.139, 0.058, 1.111)
      (0.138, 0.055, 1.11)
      (0.136, 0.06, 1.11)
      >>> for i in range(5):
      ...     print(math.sqrt(imu.acceleration[0]**2+imu.acceleration[1]**2+imu.acceleration[2]**2))
      ...     wait(1)
      1.11918095051694
      1.12111150203715
      1.12195989233127
      1.12375308675883
      1.11990892486845
      I also tried with the configuration 16g range set. More or less the same.
      >>> for i in range(5):
      ...     wait(1)
      (0.137, 0.059, 1.12)
      (0.137, 0.059, 1.11)
      (0.142, 0.062, 1.11)
      (0.139, 0.053, 1.108)
      (0.128, 0.063, 1.107)
      >>> import math
      >>> for i in range(5):
      ...     wait(1)
      1.13100221043108
      1.12003080314784
      1.1184927357833
      1.11923321966425
      1.117821094809
      路路路
        heybin
        acceleration z is 1g, is normal
        Z 1 Reply Last reply Reply Quote 0
        • Z Offline
          zhufu86 @heybin
          @heybin
          but it is 11% more than 1g.
          Is it normal? I suppose the tolerance is much lower than 10%.
            heybin
            It need calibration, maybe... i will check it
            hagueH 1 Reply Last reply Reply Quote 0
            • hagueH Offline
              hague @heybin
              @heybin I also found "non zero" values for acceleration and gyro. Is there a special calibration method?
              Thanks....
              With your input, this post could be even better 馃挆
