<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[the tolerance of sh200q of StickC?]]></title><description><![CDATA[<p dir="auto">I'm curious about the tolerance of the sh200q acceleration readings of StickC.<br />
I put the StickC on the desk and make sure it will not be moved and be steady.<br />
Then I tried the codes below but got the acceleration higher than "1g".  Why is that?</p>
<pre><code>&gt;&gt;&gt; from hardware import sh200q
&gt;&gt;&gt; import math
&gt;&gt;&gt; imu = sh200q.Sh200q()
&gt;&gt;&gt;
&gt;&gt;&gt; for i in range(5):
...     print((imu.acceleration[0],imu.acceleration[1],imu.acceleration[2]))
...     wait(1)
(0.138, 0.058, 1.107)
(0.14, 0.055, 1.111)
(0.139, 0.058, 1.111)
(0.138, 0.055, 1.11)
(0.136, 0.06, 1.11)
...     print(math.sqrt(imu.acceleration[0]**2+imu.acceleration[1]**2+imu.acceleration[2]**2))
...     wait(1)
1.11918095051694
1.12111150203715
1.12195989233127
1.12375308675883
1.11990892486845
&gt;&gt;&gt;
<p dir="auto">I also tried with the configuration 16g range set. More or less the same.</p>
<pre><code>&gt;&gt;&gt; for i in range(5):
...     wait(1)
(0.137, 0.059, 1.12)
(0.137, 0.059, 1.11)
(0.142, 0.062, 1.11)
(0.139, 0.053, 1.108)
(0.128, 0.063, 1.107)
&gt;&gt;&gt;
...     wait(1)
1.13100221043108
1.12003080314784
1.1184927357833
1.11923321966425
1.117821094809
&gt;&gt;&gt;
···</code></pre>
]]></description><link>https://community.m5stack.com/topic/1053/the-tolerance-of-sh200q-of-stickc</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 06:30:00 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1053.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 04 Jun 2019 04:36:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to the tolerance of sh200q of StickC? on Mon, 09 Dec 2019 22:41:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heybin" aria-label="Profile: heybin">@<bdi>heybin</bdi></a> I also found "non zero" values for acceleration and gyro. Is there a special calibration method?<br />
Thanks....</p>
]]></description><link>https://community.m5stack.com/post/6650</link><guid isPermaLink="true">https://community.m5stack.com/post/6650</guid><dc:creator><![CDATA[hague]]></dc:creator><pubDate>Mon, 09 Dec 2019 22:41:28 GMT</pubDate></item><item><title><![CDATA[Reply to the tolerance of sh200q of StickC? on Mon, 10 Jun 2019 01:18:46 GMT]]></title><description><![CDATA[<p dir="auto">It need calibration, maybe... i will check it</p>
]]></description><link>https://community.m5stack.com/post/4575</link><guid isPermaLink="true">https://community.m5stack.com/post/4575</guid><dc:creator><![CDATA[heybin]]></dc:creator><pubDate>Mon, 10 Jun 2019 01:18:46 GMT</pubDate></item><item><title><![CDATA[Reply to the tolerance of sh200q of StickC? on Thu, 06 Jun 2019 13:43:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heybin" aria-label="Profile: heybin">@<bdi>heybin</bdi></a></p>
<p dir="auto">but it is 11% more than 1g.<br />
Is it normal?  I suppose the tolerance is much lower than 10%.</p>
]]></description><link>https://community.m5stack.com/post/4546</link><guid isPermaLink="true">https://community.m5stack.com/post/4546</guid><dc:creator><![CDATA[zhufu86]]></dc:creator><pubDate>Thu, 06 Jun 2019 13:43:57 GMT</pubDate></item><item><title><![CDATA[Reply to the tolerance of sh200q of StickC? on Tue, 04 Jun 2019 05:49:03 GMT]]></title><description><![CDATA[<p dir="auto">acceleration z is 1g, is normal</p>
]]></description><link>https://community.m5stack.com/post/4519</link><guid isPermaLink="true">https://community.m5stack.com/post/4519</guid><dc:creator><![CDATA[heybin]]></dc:creator><pubDate>Tue, 04 Jun 2019 05:49:03 GMT</pubDate></item></channel></rss>
