    UiFlow 1.4.0 - Remote / not pulling from device
    11 Posts 2 Posters 20.0k Views 1 Watching
    • OyczEO Offline
      OyczE
      base on all tutorials / manual i am not able to push to Remote resoults from ENV.
      On screen all is fine i mean on Core unit also on Fire and Face, but all 3 units fail on remote ...
      text alternatywny
      Remote button is working fine.
      And here is dump from console:
      What is wrong ?
        ajb2k3 @OyczE
        @mati What firmware have you got installed on devices as the "Isn't defined" is normally caused by a firmware mismatch.
        • OyczEO Offline
          OyczE @ajb2k3
          @ajb2k3 1.4.0 in other way UiFlow will cry in right top border =]
            Cant see you screen shot as its so small
            • OyczEO Offline
              OyczE @ajb2k3
              @ajb2k3 yee was bad now its fixed
                ajb2k3 @OyczE
                @mati try creating a variable _remote_temp and set to 0
                • OyczEO Offline
                  OyczE @ajb2k3
                  @ajb2k3 one step forward
                  Exception:
                  TypeError("'int' object isn't callable",)
                  could you test it as well ?
                  ajb2k3A 2 Replies Last reply Reply Quote 0
                    ajb2k3 @OyczE
                    @mati I have been trying but the server has stopped working
                      ajb2k3 @OyczE
                      @mati Don't use Set variable to query a value, use change.
                      Set is used before the initial loop to set the initial value for the variable.
                      • OyczEO Offline
                        OyczE @ajb2k3
                        @ajb2k3 its almost 1:1 like in https://youtu.be/teR-_JKNxeE?t=201
                        i think its working fine a week ago, but its req fresh erase / burn. With more complex code like this:
                        remote code is not working at all, also the remote URL is not generating.
                        I think this is some backend problem.
                          ajb2k3 @OyczE
                          @mati Hmn, I think you could be correct there with the backend.
                          Put a hold on the project and try again in a couple of days or drop a bug report on the UIFLow github page.
