    ENV sensor calibration
    13 Posts 4 Posters 27.3k Views 1 Watching
      charlestondance
      Well that is not much use then!
      Is the problem the supplier or the device or the code?
      If the offset is the same within a certain range surely you could just subtract a constant? the issue is i have no way to measure humidity and pressure independently.
        ajb2k3 @charlestondance
        @charlestondance I suppose you can try using the maths blocks but I have to ask (don't take this personally) are you sure your how thermostat is calibrated?
        In UIFlow, the temperature is returned as a value and so you can add that to a maths block as a variable number.
        Below is a quick code test (sorry had to retrieve the kit from the office/studio.alt text
        • W Offline
          Wolli01 @ajb2k3
          @ajb2k3 Yes, the humidity results are really bad.
          How can I e.g. connect my own sensor SHT series?
          On my Pycom Wipy I have something like this running successfully.
          I like to set the code to change it for M5Stack.
            Connecting the sensor depends on many things like operating characteristics.
            Can you post a link to the sensor you are looking at?
            Sometime its just a case of plug and play, sometimes its a case of hacing some code.
            • W Offline
              Wolli01 @ajb2k3
              https://www.sensirion.com/en/environmental-sensors/humidity-sensors/digital-humidity-sensors-for-various-applications/
              Of these I have the SHT 20/21 and the SHT 30/31 on my
              Pycom Wipy/Lopy are doing well.
              • lukasmaximusL Offline
                @Wolli01 The sensor you sent us a link to, is it on a breakout board with pinouts? and is it possible to communicate with it via i2c?
                • W Offline
                  Wolli01 @lukasmaximus
                  @lukasmaximus Yeah, no problems.
                  Enclosed the code that runs in Wipy over Python.
                  SHT31.PY
                  from machine import I2C
                  import time
                  R_HIGH = const(1)
                  R_MEDIUM = const(2)
                  R_LOW = const(3)
                  class SHT31(object):
                  Diese Klasse implementiert eine Schnittstelle zur SHT31 Temperatur und Luftfeuchtigkeit.
                  Sensor von Sensirion.
                  # Diese statische Karte hilft, den Heap und die Programmlogik sauber zu halten.
                  _map_cs_r = {
                  True: {
                  R_HIGH : b'\x2c\x06',
                  R_MEDIUM : b'\x2c\x0d',
                  R_LOW: b'\x2c\x10'
                  False: {
                  R_HIGH : b'\x24\x00',
                  R_MEDIUM : b'\x24\x0b',
                  R_LOW: b'\x24\x16'
                  def __init__(self, i2c, addr=0x44):
                      Initialisiert ein Sensorobjekt auf dem angegebenen I2C-Bus, auf das von der
                      angegebene Adresse.
                      if i2c == None or i2c.__class__ != I2C:
                          raise ValueError('I2C-Objekt als Argument benötigt!')
                      self._i2c = i2c
                      self._addr = addr
                  def _send(self, buf):
                      Sendet das angegebene Pufferobjekt über I2C an den Sensor.
                      self._i2c.writeto(self._addr, buf)
                  def _recv(self, count):
                      Lesen von Bytes vom Sensor über I2C. Die Anzahl der Bytes kann angegeben werden.
                      als Argument.
                      Liefert ein Bytearray für das Ergebnis.
                      return self._i2c.readfrom(self._addr, count)
                  def _raw_temp_humi(self, r=R_HIGH, cs=True):
                      Lesen Sie die Rohtemperatur und Luftfeuchtigkeit vom Sensor ab und überspringen Sie CRC. Überprüfung.
                      Liefert ein Tupel für beide Werte in dieser Reihenfolge.
                      if r not in (R_HIGH, R_MEDIUM, R_LOW):
                          raise ValueError('Falscher Wiederholbarkeitswert angegeben!')
                      self._send(self._map_cs_r[cs][r])
                      time.sleep_ms(50)
                      raw = self._recv(6)
                      return (raw[0] << 8) + raw[1], (raw[3] << 8) + raw[4]
                  def get_temp_humi(self, resolution=R_HIGH, clock_stretch=True, celsius=True):
                      Lesen Sie die Temperatur in Grad Celsius oder Fahrenheit und relativ dazu ab.
                      Feuchtigkeit. Auflösung und Taktverlängerung können festgelegt werden.
                      t, h = self._raw_temp_humi(resolution, clock_stretch)
                      if celsius:
                          temp = -45 + (175 * (t / 65535.0))
                      else:
                          temp = -49 + (315 * (t / 65535.0))
                      return temp, 100 * (h / 65535.0)
                  Main.PY
                  #Sensor SHT31-----------------------------------------------------------
                  if (Sensorwahl) == 'sht31':
                  i2c = I2C(0, I2C.MASTER, baudrate=100000)
                  sensor = sht31.SHT31(i2c, addr=0x44)
                  temp_humi = sensor.get_temp_humi()
                  time.sleep(0.6)
                  pycom.rgbled(0xff007f) # magenta
                  pycom.heartbeat(False) #Lampe ausschalten um Energie zu sparen
                  Temp1 = round(temp_humi[0],2)
                  Feuchte1 = round(temp_humi[1],2)
                  time.sleep(1)
                  print('----------------------------------------------------------------------')
                  print("Ohne Runden = Temperature: {} °C | Humidity: {} %".format(temp_humi[0], temp_humi[1]))
                  #Übergabe der Sensorwerte---------------------------------------
                  Temp1 = (Temp1 + 0) #Übergabe und Differenzeingabe
                  Feuchte1 = (Feuchte1 + 0) #Übergabe und Differenzeingabe
                    The I2c implementation in UIflow firmware is a little weird, I think if you were to flash the standard micropython firmware and put the necessary libraries on there this would work fine.
                    W 2 Replies Last reply Reply Quote 0
                    • W Offline
                      @lukasmaximus Yes, I thought about that, but how do I get the display to work? I can't cope with that.
                      • W Offline
                        @lukasmaximus
                        Where can I find instructions how to integrate the M5Stack libraries into the MicroPython standard software on a M5Stack Core Grey/Black.
                          You need to use a command line program called ampy to move the libraries across. This guy wrote a guide in which he used the standard micropython firmware and added his own libraries https://www.hackster.io/andreas-motzek/execute-logo-on-m5stack-esp32-basic-with-micropython-3713fd
