    M5Stick C unable to upload code after clock example loaded
    General
    5
    10.0k
    • G
      graemea
      Testing out StickC, I uploaded the clock example. However, the USB port is now no longer seen from the Arduino IDE. I also have a M5Stick (grey) and that connects fine. Is there a way to factory reset / other way to resolve this? Thanks
        Have you tried switching the stick c off and on again? May sound silly but occasionally they needs to be properly power cycled other wise connections are lost.
        Another option is to use M5Burner to wipe the code from the device.
        • G
          graemea
          Hi, thanks for the reply - yep tried power off/on plus various combinations of button presses. Nothing appears to bring the USB back "on-line".
          o.coplestonO 1 Reply Last reply Reply Quote 0
          • o.coplestonO
            o.copleston @graemea
            @graemea try my fix here
            • lukasmaximusL
              Have you tried to erase the flash memory with the M5Burner or firmware uploader inside UIFlow offline IDE?
