<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stick C unable to upload code after clock example loaded]]></title><description><![CDATA[<p dir="auto">Hi,<br />
Testing out StickC, I uploaded the clock example. However, the USB port is now no longer seen from the Arduino IDE. I also have a M5Stick (grey) and that connects fine. Is there a way to factory reset / other way to resolve this? Thanks</p>
]]></description><link>https://community.m5stack.com/topic/1193/m5stick-c-unable-to-upload-code-after-clock-example-loaded</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 03:45:25 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/1193.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 06 Aug 2019 08:53:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stick C unable to upload code after clock example loaded on Wed, 16 Oct 2019 08:46:19 GMT]]></title><description><![CDATA[<p dir="auto">Have you tried to erase the flash memory with the M5Burner or firmware uploader inside UIFlow offline IDE?</p>
]]></description><link>https://community.m5stack.com/post/5999</link><guid isPermaLink="true">https://community.m5stack.com/post/5999</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Wed, 16 Oct 2019 08:46:19 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stick C unable to upload code after clock example loaded on Wed, 16 Oct 2019 00:04:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/graemea" aria-label="Profile: graemea">@<bdi>graemea</bdi></a> try my fix <a href="http://forum.m5stack.com/topic/1394/m5stickc-timed-out-waiting-for-packet-header-on-mac-os-catalina-fix" target="_blank" rel="noopener noreferrer nofollow ugc">here</a></p>
]]></description><link>https://community.m5stack.com/post/5991</link><guid isPermaLink="true">https://community.m5stack.com/post/5991</guid><dc:creator><![CDATA[o.copleston]]></dc:creator><pubDate>Wed, 16 Oct 2019 00:04:29 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stick C unable to upload code after clock example loaded on Wed, 07 Aug 2019 08:12:44 GMT]]></title><description><![CDATA[<p dir="auto">Hi, thanks for the reply - yep tried power off/on plus various combinations of button presses. Nothing appears to bring the USB back "on-line".</p>
]]></description><link>https://community.m5stack.com/post/5057</link><guid isPermaLink="true">https://community.m5stack.com/post/5057</guid><dc:creator><![CDATA[graemea]]></dc:creator><pubDate>Wed, 07 Aug 2019 08:12:44 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stick C unable to upload code after clock example loaded on Tue, 06 Aug 2019 09:05:17 GMT]]></title><description><![CDATA[<p dir="auto">Have you tried switching the stick c off and on again? May sound silly but occasionally they needs to be properly power cycled other wise connections are lost.</p>
<p dir="auto">Another option is to use M5Burner to wipe the code from the device.</p>
]]></description><link>https://community.m5stack.com/post/5043</link><guid isPermaLink="true">https://community.m5stack.com/post/5043</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Tue, 06 Aug 2019 09:05:17 GMT</pubDate></item></channel></rss>
