    Update m5Stack to 1.3.2
    Scheduled Pinned Locked Moved M5Stack Fire
    2 Posts 2 Posters 5.8k Views 1 Watching
      patmolloy
      I can see the m5stack on my windows 10 machine at COM11 with the correct driver. When I try to burn the new software I see the following which seems to suggest that m5burner (or some other component) cannot .. any ideas? Thanks!
      • Command:
        --chip esp32 --port COM11 --baud 921600 --before default_reset --after no_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x10000 application_0x10000.bin 0x1000 bootloader_0x1000.bin 0x1f0000 fatfsImg_0x1f0000.img 0x8000 partitions_0x8000.bin
        [25524] Failed to execute script esptool
        File "esptool.py", line 2849, in <module>
        File "esptool.py", line 2842, in main
        File "esptool.py", line 2549, in main
        File "esptool.py", line 213, in init
        File "site-packages\serial_init
        .py", line 88, in serial_for_url
        File "site-packages\serial\serialwin32.py", line 62, in open
        serial.serialutil.SerialException: could not open port 'COM11': PermissionError(13, 'A device attached to the system is not functioning.', None, 31)
        esptool.py v2.5.0
        Serial port COM11
        Check your usb cable, sometimes the cables dont work.
