    M5Stack - Simple Applications for RFID- Arduino
    9 Posts 6 Posters 29.5k Views 3 Watching
      Ddaniel
      HI,
      I would like to connect a RFID reader to a M5Stack, I have a RC522 sensor witch is connected like this SDA to SDA, SCK to SCK, MOSI to MO, MI to MI, Reset to 1. I have this code:
      #include <SPI.h>
      #include <MFRC522.h>
      #include <M5Stack.h>
      #define RST_PIN 1 //Pin 1 para el reset del RC522
      #define SS_PIN 21 //Pin 21 para el SS (SDA) del RC522
      MFRC522 mfrc522(SS_PIN, RST_PIN); //Creamos el objeto para el RC522
      Serial.begin(9600); //Iniciamos la comunicación serial
      SPI.begin(); //Iniciamos el Bus SPI
      mfrc522.PCD_Init(); // Iniciamos el MFRC522
      Serial.println("Lectura del UID");
      M5.Lcd.println("Lectura del UID");
      // Revisamos si hay nuevas tarjetas presentes
      if ( mfrc522.PICC_IsNewCardPresent())
      //Seleccionamos una tarjeta
      if ( mfrc522.PICC_ReadCardSerial())
      // Enviamos serialemente su UID
      Serial.print("Card UID:");
      M5.Lcd.println("Card UID:");
      for (byte i = 0; i < mfrc522.uid.size; i++) {
      Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
      M5.Lcd.print (mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
      Serial.print(mfrc522.uid.uidByte[i], HEX);
      M5.Lcd.print (mfrc522.uid.uidByte[i], HEX);
      Serial.println();
      M5.Lcd.println();
      // Terminamos la lectura de la tarjeta actual
      mfrc522.PICC_HaltA();
      Unfortunately does not work.
      Please, could somebody give me an advise, something simple...
      In the future I want to create a door access.
      Thank you in advance.
      • m5stackM Online
        pin 1 is for serial0, maybe not good for this.
          dda
          As @m5stack said, PIN 1 is used by Serial0. You should pick a GPIO that's not in use already.
            Ddaniel @dda
            @dda Are there any other solucions to connect RFID to M5Stack?
              dda @Ddaniel
              @ddaniel Read my answer again: don't use pin 1 for RST_PIN. Connect it to another pin that isn't used yet.
                Dave
                I am interested in a compact RFID reader with a feedback display.
                I am wondering whether you have managed to build the sensor into the stack or whether it needs to be put off to the side somewhere?
                • JJJ Offline
                  JJ @Dave
                  @dave Hi Dave,
                  I have a RFID-RC522 module on order but hasn't arrived yet... Apparently the board dimensions are: 3.9 x 6 cm
                  So unfortunately it seems the whole module won't fit inside the M5 case....
                  Might be ok with just a little sticking out the side....
                    jp128
                    You could take a look at https://www.sparkfun.com/products/11828
                    It is somewhat more expensive, but has a body type that may be able to fit just fine into a different stack, or even the protoboard. They have other models as well.
                    • JJJ Offline
                      JJ @jp128
                      @jp128 @Dave @ddaniel
                      Hi Jp128,
                      Thanks for the tip..... could be very useful.... more reading required....
