    M5Stack with a moisture sensore, Arduino IDE
    5 Posts 2 Posters 11.0k Views 1 Watching
      kat
      I need to work with the module M5stack core kit V1.0 . I try to connect a moisture Funduino sensor to this module with a Arduino IDE but i cann't do it...
      Before i have try with the sensor DHT11 and i can receive the temperature, but with the moisture sensor i don't find anything. I connected:
      • to the GND
      • to 3,3 V
        S to GPIO22
      ![0_1556289977868_Unbenannt.PNG](Uploading 100%)
      The sensor use a analogic output, you know where i need to connected the data pin about the sensor in the CORE kit?
      Thank you very much for your help.
        ajb2k3 @kat
        @kat said in M5Stack with a moisture sensore, Arduino IDE:
        • to the GND
        • to 3,3 V
          S to GPIO22
        Sorry you picture hasn't worked.
        • to 5V
        • to GND
          s to 35 or 36 on the black I/O base
          alt text
          then something like the following to read the pin.
        int analogPin = G35; // potentiometer wiper (middle terminal) connected to analog pin g35
                            // outside leads to ground and +5V
        int val = 0;  // variable to store the value read
          Serial.begin(9600);           //  setup serial
          val = analogRead(analogPin);  // read the input pin
          Serial.println(val);          // debug value
        May I ask what you are planning to use the sensor for?
          kat
          ok nice thank you for your help !
          I have connected the sensor to th pin 26 and it work.
          i want to know the humidity in the earth for my plants.
            kat
            It' show this for example:
            moisture: 0
            moisture: 125
            moisture: 658
            moisture: 1254
            What i need to put in the program to have just one line with " moisture values : " and the values changes every 1seconds?
            Like a clock
              ajb2k3 @kat
              @kat @Rop you need to create and M5ez project, create a text place holder and set the code to replace the text with the values. Hopefully @Rop will pick up the notification and help you out. My knowledge is more towards Uiflow
