I need to work with the module M5stack core kit V1.0 . I try to connect a moisture Funduino sensor to this module with a Arduino IDE but i cann't do it...
Before i have try with the sensor DHT11 and i can receive the temperature, but with the moisture sensor i don't find anything. I connected:- to the GND
- to 3,3 V
S to GPIO22
The sensor use a analogic output, you know where i need to connected the data pin about the sensor in the CORE kit?
Thank you very much for your help.
@kat said in M5Stack with a moisture sensore, Arduino IDE:
- to 3,3 V
S to GPIO22
Sorry you picture hasn't worked.
- to 5V
- to GND
s to 35 or 36 on the black I/O base
then something like the following to read the pin.
int analogPin = G35; // potentiometer wiper (middle terminal) connected to analog pin g35 // outside leads to ground and +5V int val = 0; // variable to store the value read void setup() { Serial.begin(9600); // setup serial } void loop() { val = analogRead(analogPin); // read the input pin Serial.println(val); // debug value }May I ask what you are planning to use the sensor for?
ok nice thank you for your help !
I have connected the sensor to th pin 26 and it work.
i want to know the humidity in the earth for my plants. -
It' show this for example:
moisture: 0
moisture: 125
moisture: 658
moisture: 1254What i need to put in the program to have just one line with " moisture values : " and the values changes every 1seconds?
Like a clock -
