    logic level
    M5 Stick/StickC
    3.5k
      Smrtokvitek
      So I wanted to connect the M5Stick to the CJMCU-8118 module that has 3V3 logic and needs 3V3 for power. I am not sure if I can just use some 3V3 regulator to step down the voltage from M5Stick and connect data lines directly or if I need logic level converter for data lines. I looked at the schematic on github and it looks like the grove pins are connected directly to the mcu.
      • m5-docsM
        m5-docs @Smrtokvitek
        @smrtokvitek just use some 3V3 regulator to step down the voltage from M5Stick and connect data lines directly. As you said, the data pins all connect directly to esp32.
        M5Stack documentation URL
        https://docs.m5stack.com
