    M5Stick IR
    5 Posts 4 Posters 19.0k Views 3 Watching
      cepics
      Hi all,
      is there a sketch to test IR receiver on M5Stick??
      I would like to send ir from a remote like this: alt text
      wich arduino library?
      tnks
      • m5-docsM Offline
        m5-docs @cepics
        Hello, @cepics There are some projects on Github.com you can refer to.
        https://github.com/schreibfaul1/ESP32-IR-Remote-Control
        https://github.com/luclala/IRremoteESP32
        M5Stack documentation URL
        https://docs.m5stack.com
          sergey.maysak @m5-docs
          @m5-docs thanks for pointing on this. digging the rabbit hole ended at this repo: https://github.com/crankyoldgit/IRremoteESP8266. very cool. very stable and very active to the moment.
          but unfortunately my m5stick(gray version) nor stick_c (orange version with color lcd) does not work with it.
          I used G17 for gray stick and G9 for stick_c as ir_pin - no luck - my mitsubishi AC does not respond to sent requests.
          I wondering if I need change anything in IRremoteESP8266 code to make it run over IR or what is the way to verify IR on stick or stick_c works properly.
          Specifically - the IRSend class in IRremoteESP8266 just uses:
          pinMode(IRpin, OUTPUT); -> to start
          and
          digitalWrite(IRpin, outputOn);/digitalWrite(IRpin, outputOff);
          to ledOn and ledOff
          while FactoryTest.ino for stick does this:
          ledcSetup(1, 38000, 10);
          ledcAttachPin(IrPin, 1);
          So my question is - are these two calls significant or I can ignore it?
            sergey.maysak @sergey.maysak
            OK - replying to myself just to provide information for further researchers.
            The repo https://github.com/crankyoldgit/IRremoteESP8266 works just fine (I used theirs IRMQTTServer example). compile it specifying 17 as kDefaultIrLed and that 's it. But - I've found that IR works only if I place it very very close to the subject. ie to control my AC I have to place it say in 20 cm to its IR receiver... that was really unexpected....
            @m5-docs so question is - I use default parameter for IRSend library which assumes usage of 50% duty. can I increase duty to 100% safely (w/o risk to destroy IR Led on my M5Stick or on M5StcikC - I have both) in order to increase distance?
              macsbug @sergey.maysak
              Below are examples of M5StickC and IR.
              https://qiita.com/poruruba/items/34220a4dd6aaf48392aa
              https://lang-ship.com/blog/?p=886
              https://lab.sasapea.mydns.jp/2019/06/28/m5stickc-ir/
              https://note.com/ssktkr/n/ne9f289509bea
