    stick s3 troubleshooting help
    9 Posts 4 Posters 4.7k Views
      TimmyProgamsStuff
      hi everyone, need help troubleshooting my stick s3 because i tried to burn a firmware from m5burner and now nothing is happening, and the lcd isnt turning on but the green light is on. im new to programming so im not sure what to do. any help would be much appriciated :)
      robskiR A 2 Replies Last reply Reply Quote 0
      • robskiR Offline
        robski @TimmyProgamsStuff
        @TimmyProgamsStuff erase and burn again, just be sure you pick correct firmware for device,
          aleekwen @TimmyProgamsStuff
          @TimmyProgamsStuff probably need to be in download mode - the green light needs to be flashing.
          Press left side button for 2 seconds then plug into usb cable attached to the computer - green light should be flashing.
          If it was flashed (at least on computer it says it was), disconnect the sticks3 from the computer. If green light is flashing press left button for 6 seconds then press once quickly again - green light should come on then LCD should turn on properly
            TimmyProgamsStuff @aleekwen
            @aleekwen unfortunatly this did not work
            M A 2 Replies Last reply Reply Quote 0
              TimmyProgamsStuff @robski
              @robski i also attempted this and it did work
              • M Online
                Mamoulian @TimmyProgamsStuff
                @TimmyProgamsStuff Try updating it via webburner in Uiflow2. I couldn't do it either, this helped.
                  @TimmyProgamsStuff maybe try from another computer if you have access - sometimes (at least on older windows, the usb drivers may cause the m5stick to not be recognized).
                  Reboot the computer also (just in case).
                    TimmyProgamsStuff @Mamoulian
                    @Mamoulian this worked, thank you so much!!!
                    • M Online
                      @TimmyProgamsStuff I'm glad about that. Have a lot of fun
