    Tab5 RTC backup battery specifications
    PRODUCTS
    278
    • easytargetE
      easytarget
      I'm wondering if anybody can answer this; the Tab5 has a RTC chip with a dedicated backup battery on the PCB:
      Does anybody have electrical specs for this part? or a part number? It would be really handy to have this info.
      • The rx8310 RTC chip has a number of settings for controlling and monitoring it's backup battery, it can charge rechargeable ones (for instance) and has configurable switching levels.
      • You need to know what type/capacity of battery you are working with to set this up correctly. The defauls are for a simple non-rechargable cell. Is this what the Tab5 has?
        sam_20 @easytarget
        @easytarget, I found out where’s the battery in the schematics pdf, but it doesn’t say what is the battery type
          felmue @sam_20
          Hello guys
          it is listed in the specifications here.
          RTC Chip: RX8130CE (supports timed interrupt wake-up), RTC supercapacitor specification: 70000μF/3.3V, size Φ4.8×1.4mm
          Edit: If I am not mistaken RTC battery charging is enabled with this line in M5Unified library.
          S easytargetE 3 Replies Last reply Reply Quote 1
            sam_20 @felmue
              sam_20 @felmue
              @felmue ok, but is the battery always have to be swapped every time it’s faulty?
                felmue @sam_20
                Hello @sam_20
                hmm, I don't think I understand you statement. Doesn't every electronic part that's faulty need to be swapped? What am I missing here?
                • easytargetE
                  easytarget @felmue
                  @felmue said in Tab5 RTC backup battery specifications:
                  RTC supercapacitor
                  Once again, thankyou, :-) I am getting cynical, it never occurred to me to just check the specs. doh!
                  It's a supercapacitor, which explains what I'm seeing. the chip loses time if power is off (fully off, no main battery or usb power) for more than a few minutes. I was hoping that is because it is a supercapacitor and needs a charge, but reluctant to turn charge on if it was just a dud silverNickel cell.
                  For context: I'm writing a micropython driver for this chip and testing / debugging on my Tab5. I need to go to the datasheet and work out the correct bits to set in my driver. That link to the M5Unified library is really appreciated too!
                  @sam_20 :
                  The rx8130ce has built-in fault detection for the backup battery. So it makes sense for M5 to enable it in the M5Unified init() routines. I will be working out (or just copying..) the correct settings myself and setting up my boot.py to enable 'charge' for this as well as the main battery at boot. My driver is generic, it will support all of the 8130's power modes and flags. It will default to charge off because that is safest.
                    felmue @easytarget
                    Hello @easytarget
                    FYI: I ran a test and after charging the RTC battery / supercap for a couple of minutes, setting a start time, then removing all other power sources and checking after about 7 hours later, the time in the RTC was still correct.
