    Not Connecting to Wifi - First Setup
    10 Posts 4 Posters 19.2k Views 1 Watching
      Slumnit
      Trying to setup my new M5Stack (Core) for the first time; I'm at the Wifi setup point, but it keeps failing to connect to my local Wifi;
      LCD initializing...
      Done!
      WiFi AP WebServer Start!
      Connect to Wifi SSID:M5Stack-a00d
      And connect to esp via your web browser (like 192.168.4.1)
      listening on ('0.0.0.0', 80)
      {'ssid': 'XXX+2.4G', 'password': 'XXXXXXXXXX'}
      M5Stack Core try to connect WiFi: SSID:XXX+2.4G PASSWD:XXXXXXXXXX network...
      Problem. Not Connected to :XXX+2.4G
      It doesn't even detect the 5Ghz connection. And won't connected to the 2.4Ghz wifi
        Slumnit
        So apparently you can not connect to a WiFi network with a Space in the name; since I'm not going to go around and reset all the wifi connected in the 20+ wireless devices in my home, then this M5Stack is useless.
        Furthermore; after getting it to connect to a hotspot (running off my iPhone) playing a tone: Speaker.beep freq:1600 duration: 200ms (same shown in an example video from M5Stack.com) the device crashes and reboots every time..
        ajb2k3A M 2 Replies Last reply Reply Quote 0
        • lukasmaximusL Offline
          Hi Slumnit, sounds very unusual. Which firmware are you using? and do you have anything connected to the gpio ports of the m5stack?
            ajb2k3 @Slumnit
            @slumnit said in Not Connecting to Wifi - First Setup:
            What is your code that causes this crash?
              Slumnit @lukasmaximus
              @lukasmaximus Nothing is connected; I had just opened it after it was delivered, and then follows some of the video available on M5Stack.com And whatever is the most recent virmware that i downloaded from M5stack instructed by the video on how to upgrade firmware
                Slumnit @ajb2k3
                @ajb2k3 I just did what shown here in the video https://youtu.be/rdz6hBoqamA?t=261
                using the uFlow to add the speaker.beep
                Mine doesn't make a short "beep" like in the video, it makes a distorted beep for about 3-5 seconds then reboots.
                https://streamable.com/wgw6v
                  have you tried updating the uiflow firmware?
                    Slumnit @ajb2k3
                    @ajb2k3 well as I mentioned in the response above the one to you, I had updated the firmware according to the video on the M5stack.com website; as the only video available that walks you through the process, has you install the uFlow firmware.
                    I've flashed it several times in fact; with the same end results.
                    The worse part is the super annoying buzz that comes from the speaker; and then after it sitting there powered on for a few hours the cheap adhesive pads they used to attach the screen cover started failing, and the screen cover started lifting at the top.
                      ajb2k3 @Slumnit
                      Sorry missed the message above.
                      Contact M5Stack via email and let them know. It sounds like you have a bad unit.
                        Mikey Wetzel @Slumnit
                        I had the same problem. But I did decide to rename all my APs and every device connected. 30 minutes later, still can't get a device code, and it seems like it got stuck booting into the "Press next for instructions" screen, so I can't change the wifi if I wanted to :(
