M5StickCPlus2 won’t boot after installing Bruce via Web Updater
When ever I try holding the power button it just shows a green light until I stop holding it. Can I fix it? I’m on a Mac Sequioa and whenever I try to reinstall it it just does the same thing. Also it just says this when I try to use any firmware on the M5Burner. Someone please help me!! It says this “ auto --port /dev/tty.usbserial-586B0029231--baud 1500000 --before default_reset write_flash -z --flash_mode dio --flash_freq 8 flash_size detect 0x000 /Applications/M5Burner.app/Contents/Resources/packages/firmware/67e26d43292e054e605d6ec74f8163d
ode-select: note: No developer tools were found, requesting install.
developer tools are located at a non-default location on disk, use sudo xcode-select --switch path/to/Xcode.app to specify the Xcode t hat you wish to use for command line developer tools, and cancel the installation dialog.
See man xcode-select for more details” -
@kaidencoolkid tried to "erase" first? or try to install simple arduino sketch to it. Is com port detected by pc when Stic is connected to usb?
@kaidencoolkid Did you know that Bruce is Hacking software like Nemo and Marauder, a Flipper Zero wannabe?
Don't install this software.
@robski I’m sort of new can you help me to how to erase it when I try to update it makes like errors or something it can detect the usb it says like “usbmoddem”or something I’m on Mac should I try windows?
@kaidencoolkid usb modem means not detected
@kaidencoolkid what device? I have a video on YouTube
@ajb2k3 ohhhhh I did not know that thank you I will try a different one
@ajb2k3 m5stickcplus2
