    Power Supply of M5Stack Core2
    2 Posts 2 Posters 2.0k Views
    • L Offline
      laursena
      Hi everyone,
      I have a system with multiple components connected in parallel. The setup consists of 4 PA Hubs, each connected to 6 I2C weight measurement units. These PA Hubs are then connected to a 4-way relay unit. I’m considering using an M5Stack Core2 to power and control the entire system, but I’m unsure if it’s compatible or capable of handling this configuration. Could you provide insights on whether the M5Stack Core2 is suitable for this setup?
      Thank you!
        felmue @laursena
        Hello @laursena
        unfortunately I don't know the answer to your question about the power consumption and if M5Core2 can handle it.
        However what I can tell you is that you do not necessarily need the PaHubs. The M5Stack I2C weight measurement units allow for the I2C address to be modified - so you could give each unit its own I2C address and simply connect them in parallel.
