<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Power Supply of M5Stack Core2]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">I have a system with multiple components connected in parallel. The setup consists of 4 PA Hubs, each connected to 6 I2C weight measurement units. These PA Hubs are then connected to a 4-way relay unit. I’m considering using an M5Stack Core2 to power and control the entire system, but I’m unsure if it’s compatible or capable of handling this configuration. Could you provide insights on whether the M5Stack Core2 is suitable for this setup?</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://community.m5stack.com/topic/7033/power-supply-of-m5stack-core2</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 14:09:45 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7033.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 29 Nov 2024 14:44:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Power Supply of M5Stack Core2 on Fri, 29 Nov 2024 19:37:04 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/laursena" aria-label="Profile: laursena">@<bdi>laursena</bdi></a></p>
<p dir="auto">unfortunately I don't know the answer to your question about the power consumption and if M5Core2 can handle it.</p>
<p dir="auto">However what I can tell you is that you do not necessarily need the PaHubs. The M5Stack I2C weight measurement units allow for the I2C address to be modified - so you could give each unit its own I2C address and simply connect them in parallel.</p>
]]></description><link>https://community.m5stack.com/post/27235</link><guid isPermaLink="true">https://community.m5stack.com/post/27235</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 29 Nov 2024 19:37:04 GMT</pubDate></item></channel></rss>
