    M5CoreS3: "ERROR Device type unknown" when trying to connect both CoreS3 and CoreS3 SE to Server.
    12 Posts 5 Posters 5.5k Views
    • teastainT Offline
      teastain @PhilB79
      @PhilB79 Can you upload a small Arduino IDE test file?
      Like a generic serial monitor test?
        ajb2k3 @PhilB79
        @PhilB79 What's reporting the error?
          PhilB79 @PhilB79
          @PhilB79
          Yes to the latest version more the once
            PhilB79 @teastain
            @teastain
            UIflow 2 / Select device / RED dot next to the CoreS3 graphic. Same applies to CoreS3
              PhilB79 @robski
              @robski
              Can do but not until later today
              • robskiR Offline
                robski @PhilB79
                @PhilB79 you have to use M5Burner when loogged in so firmware update "binds" your device in to your uiflow account and then it is visible on the list if connected to internet.
                  PhilB79 @robski
                  @robski said in M5CoreS3: "ERROR Device type unknown" when trying to connect both CoreS3 and CoreS3 SE to Server.:
                  Yes I use the full process of Erase, Bind and Burn. Tried many time but still the Red dot in device select.
                  I'm about to give up and put the lot in the bin and go back to ESP32s
                  felmueF robskiR 2 Replies Last reply Reply Quote 0
                    felmue @PhilB79
                    Hello @PhilB79
                    before you give up.
                    For the dot to turn green of any M5Core in the My Device list the M5Core needs to have a wireless connection and an established connection to the UIFlow2 cloud server.
                    On the initial UIFlow2 screen on the M5Core there are two symbols, one for wireless and one for the cloud server, in the top right corner (next to the battery symbol).
                    • the wireless symbol needs to be not crossed out.
                    • the cloud server symbol needs to be without question mark.
                    Below are the steps these two icons go through after boot up / reset of the M5Core:
                    UIFlow2_WirelessNOK_CloudNOK_20241018.png Wireless not ok - Cloud not ok
                    UIFlow2_WirelessOK_CloudNOK_20241018.png Wireless ok - Cloud not ok
                    UIFlow2_WirelessOK_CloudOK_20241018.png Wireless ok - Cloud ok
                    • robskiR Offline
                      robski @PhilB79
                      @PhilB79 so after such process is your device showing connected to uiflow cloud? is it showing your email address (all should be visible on device startup page)
                      • robskiR Offline
                        robski @PhilB79
                        @PhilB79 said in M5CoreS3: "ERROR Device type unknown" when trying to connect both CoreS3 and CoreS3 SE to Server.:
                        @teastain
                        silly question but you are logged in to Uiflow2 with same login credentials as in M5Burner (bind)
