    Real-time Audio Monitoring with AtomS3U
    1 Posts 1 Posters 1.1k Views
    • E Offline
      Etherist
      I would like to use the AtomS3U to behave as a wireless real-time audio broadcaster. I have seen that the ESP-32S3 is capable of doing this with an IMP441 using a node server (see here), but haven't had success using the AtomS3U's onboard PDM.
      I've attached my code, which is mostly a modified version of the program written by ThatProject in the linked YouTube video. I've also incorporated some code from the PDM unit Arduino example by M5Stack (see here).
      So far, I am able to run the server and establish connection to the AtomS3U, however, when I try and stream the audio, I either get static noise, or nothing at all.
      #include <driver/i2s.h>
      #include <WiFi.h>
      #include <ArduinoWebsockets.h>
      #define I2S_SD 38
      #define I2S_SCK 39
      #define I2S_PORT I2S_NUM_0
      #define bufferCnt 2
      #define bufferLen 128
      int16_t sBuffer[bufferLen];
      const char* ssid = "spider_gateway";
      const char* password = "TMTspider1";
      const char* websocket_server_host = "192.168.24.246";
      const uint16_t websocket_server_port = 8888;  // <WEBSOCKET_SERVER_PORT>
      using namespace websockets;
      WebsocketsClient client;
      bool isWebSocketConnected;
      void onEventsCallback(WebsocketsEvent event, String data) {
        if (event == WebsocketsEvent::ConnectionOpened) {
          Serial.println("Connnection Opened");
          isWebSocketConnected = true;
        } else if (event == WebsocketsEvent::ConnectionClosed) {
          Serial.println("Connnection Closed");
          isWebSocketConnected = false;
        } else if (event == WebsocketsEvent::GotPing) {
          Serial.println("Got a Ping!");
        } else if (event == WebsocketsEvent::GotPong) {
          Serial.println("Got a Pong!");
      void i2s_install() {
        // Set up I2S Processor configuration
        const i2s_config_t i2s_config = {
          .mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_RX | I2S_MODE_PDM),
          .sample_rate = 44100,
          .bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT, // is fixed at 12bit, stereo, MSB
          .channel_format = I2S_CHANNEL_FMT_ONLY_RIGHT,
          .communication_format = I2S_COMM_FORMAT_I2S,
          .intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,
          .dma_buf_count = bufferCnt,
          .dma_buf_len = bufferLen,
        i2s_driver_install(I2S_PORT, &i2s_config, 0, NULL);
      void i2s_setpin() {
        // Set I2S pin configuration
        const i2s_pin_config_t pin_config = {
          .bck_io_num = I2S_PIN_NO_CHANGE,
          .ws_io_num  = I2S_SCK,
          .data_out_num = I2S_PIN_NO_CHANGE,
          .data_in_num = I2S_SD,
        i2s_set_pin(I2S_PORT, &pin_config);
        //Serial.println("Init i2s_set_clk");
        i2s_set_clk(I2S_PORT, 44100, I2S_BITS_PER_SAMPLE_16BIT, I2S_CHANNEL_MONO);
        Serial.begin(115200);
        connectWiFi();
        connectWSServer();
        xTaskCreatePinnedToCore(micTask, "micTask", 10000, NULL, 1, NULL, 1);
      void connectWiFi() {
        WiFi.begin(ssid, password);
          delay(500);
          Serial.print(".");
        Serial.println("");
        Serial.println("WiFi connected");
      void connectWSServer() {
        client.onEvent(onEventsCallback);
        while (!client.connect(websocket_server_host, websocket_server_port, "/")) {
          delay(500);
          Serial.print(".");
        Serial.println("Websocket Connected!");
      void micTask(void* parameter) {
        i2s_install();
        i2s_setpin();
        i2s_start(I2S_PORT);
        size_t bytesIn = 0;
        while (1) {
          esp_err_t result = i2s_read(I2S_PORT, &sBuffer, bufferLen, &bytesIn, portMAX_DELAY);
          if (result == ESP_OK && isWebSocketConnected) {
            client.sendBinary((const char*)sBuffer, bytesIn);
      Thanks in advance for any tips.
