<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Real-time Audio Monitoring with AtomS3U]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I would like to use the AtomS3U to behave as a wireless real-time audio broadcaster. I have seen that the ESP-32S3 is capable of doing this with an IMP441 using a node server (see <a href="https://youtu.be/qq2FRv0lCPw" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>), but haven't had success using the AtomS3U's onboard PDM.</p>
<p dir="auto">I've attached my code, which is mostly a modified version of the program written by ThatProject in the linked YouTube video. I've also incorporated some code from the PDM unit Arduino example by M5Stack (see <a href="https://github.com/m5stack/M5-ProductExampleCodes/blob/master/Unit/PDM/PDM.ino" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>).</p>
<p dir="auto">So far, I am able to run the server and establish connection to the AtomS3U, however, when I try and stream the audio, I either get static noise, or nothing at all.</p>
<pre><code>#include &lt;driver/i2s.h&gt;
#include &lt;WiFi.h&gt;
#include &lt;ArduinoWebsockets.h&gt;
#define I2S_SD 38
#define I2S_SCK 39
#define I2S_PORT I2S_NUM_0
#define bufferCnt 2
#define bufferLen 128
int16_t sBuffer[bufferLen];
const char* ssid = "spider_gateway";
const char* password = "TMTspider1";
const char* websocket_server_host = "192.168.24.246";
const uint16_t websocket_server_port = 8888;  // &lt;WEBSOCKET_SERVER_PORT&gt;
using namespace websockets;
WebsocketsClient client;
bool isWebSocketConnected;
void onEventsCallback(WebsocketsEvent event, String data) {
  if (event == WebsocketsEvent::ConnectionOpened) {
    Serial.println("Connnection Opened");
    isWebSocketConnected = true;
  } else if (event == WebsocketsEvent::ConnectionClosed) {
    Serial.println("Connnection Closed");
    isWebSocketConnected = false;
  } else if (event == WebsocketsEvent::GotPing) {
    Serial.println("Got a Ping!");
  } else if (event == WebsocketsEvent::GotPong) {
    Serial.println("Got a Pong!");
void i2s_install() {
  // Set up I2S Processor configuration
  const i2s_config_t i2s_config = {
    .mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_RX | I2S_MODE_PDM),
    .sample_rate = 44100,
    .bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT, // is fixed at 12bit, stereo, MSB
    .channel_format = I2S_CHANNEL_FMT_ONLY_RIGHT,
    .communication_format = I2S_COMM_FORMAT_I2S,
    .intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,
    .dma_buf_count = bufferCnt,
    .dma_buf_len = bufferLen,
  i2s_driver_install(I2S_PORT, &amp;i2s_config, 0, NULL);
void i2s_setpin() {
  // Set I2S pin configuration
  const i2s_pin_config_t pin_config = {
    .bck_io_num = I2S_PIN_NO_CHANGE,
    .ws_io_num  = I2S_SCK,
    .data_out_num = I2S_PIN_NO_CHANGE,
    .data_in_num = I2S_SD,
  i2s_set_pin(I2S_PORT, &amp;pin_config);
  //Serial.println("Init i2s_set_clk");
  i2s_set_clk(I2S_PORT, 44100, I2S_BITS_PER_SAMPLE_16BIT, I2S_CHANNEL_MONO);
  Serial.begin(115200);
  connectWiFi();
  connectWSServer();
  xTaskCreatePinnedToCore(micTask, "micTask", 10000, NULL, 1, NULL, 1);
void connectWiFi() {
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
void connectWSServer() {
  client.onEvent(onEventsCallback);
  while (!client.connect(websocket_server_host, websocket_server_port, "/")) {
    delay(500);
    Serial.print(".");
  Serial.println("Websocket Connected!");
void micTask(void* parameter) {
  i2s_install();
  i2s_setpin();
  i2s_start(I2S_PORT);
  size_t bytesIn = 0;
  while (1) {
    esp_err_t result = i2s_read(I2S_PORT, &amp;sBuffer, bufferLen, &amp;bytesIn, portMAX_DELAY);
    if (result == ESP_OK &amp;&amp; isWebSocketConnected) {
      client.sendBinary((const char*)sBuffer, bytesIn);
<p dir="auto">Thanks in advance for any tips.</p>
]]></description><link>https://community.m5stack.com/topic/6894/real-time-audio-monitoring-with-atoms3u</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Mar 2026 16:37:48 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/6894.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Oct 2024 09:34:54 GMT</pubDate><ttl>60</ttl></channel></rss>
