    Trouble flashing AWS-S3-PUT example to TimerCam-F with ESP-IDF + PlatformIO
    ESP - IDF
    3.1k
    • I
      inteladata
      The project compiles fine, but fails to flash, failing with the following. Has anyone encountered and resolved this?
      Building in release mode
      Retrieving maximum program size .pio/build/m5stack-timer-cam/firmware.elf
      Checking size .pio/build/m5stack-timer-cam/firmware.elf
      Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
      RAM:   [=         ]  11.6% (used 38052 bytes from 327680 bytes)
      Flash: [==========]  96.0% (used 1006333 bytes from 1048576 bytes)
      Configuring upload protocol...
      AVAILABLE: cmsis-dap, esp-bridge, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
      CURRENT: upload_protocol = esptool
      Looking for upload port...
      Auto-detected: /dev/cu.usbserial-59527C0548
      Uploading .pio/build/m5stack-timer-cam/firmware.bin
      esptool.py v4.5.1
      Serial port /dev/cu.usbserial-59527C0548
      Connecting....
      Chip is ESP32-D0WDQ6-V3 (revision v3.1)
      Crystal is 40MHz
      MAC: b0:b2:1c:60:bf:b0
      Uploading stub...
      Running stub...
      Stub running...
      Changing baud rate to 460800
      Changed.
      A fatal error occurred: Unable to verify flash chip connection (No serial data received.).
      *** [upload] Error 2
        M5User-60283 @inteladata
        @inteladata Try setting baud rate to 1500000.
