    Simple Example of ESP-NOW Communication Between StickC Plus and M5Core Basic
    UIFlow
    2.9k
    • R
      Robertof
      I am working on a project that requires wireless communication between a StickC Plus and an M5Core Basic using the ESP-NOW protocol. I am new to this and would greatly appreciate it if someone could provide me with a simple example to establish this communication.
      I have found some tutorials on ESP-NOW, but I would like to see a specific example for these devices. Any help or example code would be greatly appreciated.
      • teastainT
        teastain @Robertof
        • teastainT
          teastain
          I wrote this VERY terse, simplistic code to demonstrate ESP-NOW.
You simply copy this code to an empty Arduino IDE sketch and change the particulars:
I.e.
Mac address
LED pin and Button pin
          Both M5Stack units, regardless of type use the same code except for the particulars, especially the MAC address.
The demo sends a boolean single bit signal when its button is pressed and the other receives it and turns on its LED:
You can easily convert it to send and receive an int or a float, whatever!
It was written for two StickC Plus, but any ESP32 will do.
          #include <Arduino.h>
          #include <esp_now.h>
          #include <WiFi.h>
          #define LED 10  // or whatever you have
          #define Button 37
          //Below is the address of the other unit
          uint8_t broadcastAddress[] = { 0x94, 0xB9, 0x7E, 0x8C, 0x7C, 0xE8 };
          String success;
          typedef struct struct_message {
            bool State;
          } struct_message;
          // Create a struct_message to hold outgoing button
          struct_message TxButton;
          // Create a struct_message to hold incoming button (to turn on this LED)
          struct_message RxButton;  //I.E. = incomingReadings
          // Register peer
          esp_now_peer_info_t peerInfo;
            Serial.begin(115200);
            pinMode(LED, OUTPUT);
            digitalWrite(LED, HIGH);
            pinMode(Button, INPUT);
            WiFi.mode(WIFI_STA);
            // Init ESP-NOW
            if (esp_now_init() != ESP_OK) {
              Serial.println("Error initializing ESP-NOW");
              return;
            // get the status of Trasnmitted packet
            esp_now_register_send_cb(OnDataSent);
            memcpy(peerInfo.peer_addr, broadcastAddress, 6);
            peerInfo.channel = 0;
            peerInfo.encrypt = false;
            // Add peer
            if (esp_now_add_peer(&peerInfo) != ESP_OK) {
              Serial.println("A- Failed to add peer");
              return;
            // Register for a callback function that will be called when data is received
            esp_now_register_recv_cb(OnDataRecv);
            delay(1000);
            TxButton.State = digitalRead(Button);  //***this is where you tramsmit this units button state
            esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *)&TxButton, sizeof(TxButton));
            if (result == ESP_OK) {
              Serial.println("Sent with success");
            } else {
              Serial.println("Error sending the data");
            delay(500);
          // OnDataRecv when data is received, LED is controlled here
          void OnDataRecv(const uint8_t *mac, const uint8_t *incomingData, int len) {
            memcpy(&RxButton, incomingData, sizeof(RxButton));
            Serial.print("Bytes received: ");
            Serial.println(len);
            digitalWrite(LED, RxButton.State);  //***this is where you receive the state of the other unit's button
          void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
            Serial.print("\r\nA- Last Packet Send Status:\t");
            Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
            if (status == 0) {
              success = "Delivery Success :)";
            } else {
              success = "Delivery Fail :(";
          • R
            Robertof @teastain
            Hi @teastain .
            I don’t know how to program in C++, that’s why I have fun with the Uiflow blocks.
            I am very grateful for your intention to help me and I will try to test the code, although modifying it will be my problem.
