Simple Example of ESP-NOW Communication Between StickC Plus and M5Core Basic
I am working on a project that requires wireless communication between a StickC Plus and an M5Core Basic using the ESP-NOW protocol. I am new to this and would greatly appreciate it if someone could provide me with a simple example to establish this communication.
I have found some tutorials on ESP-NOW, but I would like to see a specific example for these devices. Any help or example code would be greatly appreciated.
This post is deleted! -
I wrote this VERY terse, simplistic code to demonstrate ESP-NOW.
You simply copy this code to an empty Arduino IDE sketch and change the particulars:
I.e.
Mac address
LED pin and Button pin
Both M5Stack units, regardless of type use the same code except for the particulars, especially the MAC address.
The demo sends a boolean single bit signal when its button is pressed and the other receives it and turns on its LED:
You can easily convert it to send and receive an int or a float, whatever!
It was written for two StickC Plus, but any ESP32 will do.#include <Arduino.h> #include <esp_now.h> #include <WiFi.h> #define LED 10 // or whatever you have #define Button 37 //Below is the address of the other unit uint8_t broadcastAddress[] = { 0x94, 0xB9, 0x7E, 0x8C, 0x7C, 0xE8 }; String success; typedef struct struct_message { bool State; } struct_message; // Create a struct_message to hold outgoing button struct_message TxButton; // Create a struct_message to hold incoming button (to turn on this LED) struct_message RxButton; //I.E. = incomingReadings // Register peer esp_now_peer_info_t peerInfo; void setup() { Serial.begin(115200); pinMode(LED, OUTPUT); digitalWrite(LED, HIGH); pinMode(Button, INPUT); WiFi.mode(WIFI_STA); // Init ESP-NOW if (esp_now_init() != ESP_OK) { Serial.println("Error initializing ESP-NOW"); return; } // get the status of Trasnmitted packet esp_now_register_send_cb(OnDataSent); memcpy(peerInfo.peer_addr, broadcastAddress, 6); peerInfo.channel = 0; peerInfo.encrypt = false; // Add peer if (esp_now_add_peer(&peerInfo) != ESP_OK) { Serial.println("A- Failed to add peer"); return; } // Register for a callback function that will be called when data is received esp_now_register_recv_cb(OnDataRecv); delay(1000); } void loop() { TxButton.State = digitalRead(Button); //***this is where you tramsmit this units button state esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *)&TxButton, sizeof(TxButton)); if (result == ESP_OK) { Serial.println("Sent with success"); } else { Serial.println("Error sending the data"); } delay(500); } // OnDataRecv when data is received, LED is controlled here void OnDataRecv(const uint8_t *mac, const uint8_t *incomingData, int len) { memcpy(&RxButton, incomingData, sizeof(RxButton)); Serial.print("Bytes received: "); Serial.println(len); digitalWrite(LED, RxButton.State); //***this is where you receive the state of the other unit's button } void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) { Serial.print("\r\nA- Last Packet Send Status:\t"); Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail"); if (status == 0) { success = "Delivery Success :)"; } else { success = "Delivery Fail :("; } } -
Hi @teastain .
I don’t know how to program in C++, that’s why I have fun with the Uiflow blocks.
I am very grateful for your intention to help me and I will try to test the code, although modifying it will be my problem.
