    Core2 + Lan Module 13.2 + ENV IV help!
    5 Posts 2 Posters 2.7k Views
      FlooidOps
      Hey guys,
      I have a Core2 with Lan module attached and an ENV IV unit plugged in.
      I'm trying to send the recorded data from the ENV IV sensors to a server by POST request
      I have succesfully ran an arduino example that collects data from both sensors and displays to the screen and to the serial monitor.
      https://github.com/m5stack/M5Unit-ENV/blob/master/examples/Unit_ENVIV_M5Core2/Unit_ENVIV_M5Core2.ino
      I have also successfully ran the following example that performs a GET and a POST request and displays the results.
      https://github.com/m5stack/M5Module-LAN-13.2/blob/main/examples/HTTP/HTTP.ino
      Now I've attempted to combine the two and the below is what I've ended up with. The problem I'm facing is that it compiles ok, but only the bmp280 sensor gives any data, the SHT40 gives 'Error writing to I2C bus'. Can anyone see what I'm doing wrong or does the LAN module just block the SHT40 somehow?
      Serial:
      making GET request
      Status code: 200
      Response: {
        "args": {},
        "headers": {
          "Host": "httpbin.org",
          "User-Agent": "Arduino/2.2.0",
          "X-Amzn-Trace-Id": "Root=1-66574f8b-19e46aa01976708f76ff6811"
        "origin": "81.96.198.248",
        "url": "http://httpbin.org/get"
      making POST request
      Error trying to execute measureHighPrecision(): Error writing to I2C bus
      ,,99983.526679
      Code:
      #include <M5Unified.h>
      #include <Wire.h>
      #include <M5GFX.h>
      #include <SPI.h>
      #include <M5Module_LAN.h>
      #include <ArduinoHttpClient.h>
      #include <SensirionI2cSht4x.h>
      #include <Adafruit_BMP280.h>
      #include "Adafruit_Sensor.h"
      #define THEME_COLOR 0x0760
      #define SERVER "httpbin.org"
      #define POST_INTERVAL 5000
      Adafruit_BMP280 bmp;
      SensirionI2cSht4x sht;
      float temp, pressure, humd;
      long lastTime = 0;
      uint8_t cs_pin;
      uint8_t rst_pin;
      uint8_t int_pin;
      int screen_height;
      int screen_width;
      byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0x89};
      M5Module_LAN LAN;
      M5Canvas canvas(&M5.Display);
      EthernetClient ethClient;
      HttpClient client = HttpClient(ethClient, SERVER);
          M5.Display.begin();
          M5.Display.setTextColor(WHITE);
          M5.Display.setTextFont(&fonts::FreeSansBoldOblique18pt7b);
          screen_height = M5.Display.height();
          screen_width  = M5.Display.width();
          while (!bmp.begin(0x76))
          { // Init this sensor,True if the init was successful, otherwise
            // false.
              M5.Lcd.println("Could not find a valid BMP280 sensor, check wiring!");
              Serial.println(F("BMP280 fail"));
          uint16_t error;
          char errorMessage[256];
          Wire.begin();
          sht.begin(Wire, 0x44);
          uint32_t serialNumber;
          error = sht.serialNumber(serialNumber);
          if (error)
              Serial.print("Error trying to execute serialNumber(): ");
              errorToString(error, errorMessage, 256);
              Serial.println(errorMessage);
          else
              Serial.print("Serial Number: ");
              Serial.println(serialNumber);
          bmp.setSampling(Adafruit_BMP280::MODE_NORMAL,     /* Operating Mode. */
                          Adafruit_BMP280::SAMPLING_X2,     /* Temp. oversampling */
                          Adafruit_BMP280::SAMPLING_X16,    /* Pressure oversampling */
                          Adafruit_BMP280::FILTER_X16,      /* Filtering. */
                          Adafruit_BMP280::STANDBY_MS_500); /* Standby time. */
          Serial.print("Serial initialized...");
          M5.Lcd.clear();
          M5.Display.fillSmoothRoundRect(2, 2, screen_width - 4, 36, 4, THEME_COLOR);
          M5.Display.drawString("Wait For Ethernet", screen_width / 2, 22);
          M5.Display.drawRoundRect(2, 40, screen_width - 4, 192, 4, THEME_COLOR);
          canvas.createSprite(280, 160);
          canvas.setTextColor(WHITE);
          canvas.setTextFont(&fonts::FreeSansBoldOblique9pt7b);
          canvas.setTextScroll(true);
          canvas.setTextSize(0.5);
          cs_pin  = 33;
          rst_pin = 0;
          int_pin = 35;
          SPI.begin(SCK, MISO, MOSI, -1);
          LAN.setResetPin(rst_pin);
          LAN.reset();
          LAN.init(cs_pin);
          while (LAN.begin(mac) != 1) {
              Serial.println("Error getting IP address via DHCP, trying again...");
              delay(2000);
          // Check for Ethernet hardware present
          if (Ethernet.hardwareStatus() == EthernetNoHardware) {
              Serial.println(
                  "Ethernet shield was not found.  Sorry, can't run without "
                  "hardware. :(");
              while (true) {
                  delay(1);  // do nothing, no point running without Ethernet hardware
          if (Ethernet.linkStatus() == LinkOFF) {
              Serial.println("Ethernet cable is not connected.");
      String t,h,p;
          Serial.println("making GET request");
          canvas.println("making GET request");
          canvas.pushSprite(20, 55);
          client.get("/get");
          // read the status code and body of the response
          int statusCode  = client.responseStatusCode();
          String response = client.responseBody();
          Serial.print("Status code: ");
          Serial.println(statusCode);
          Serial.print("Response: ");
          Serial.println(response);
          M5.Display.drawString("HTTP POST", screen_width / 2, 22);
          uint16_t error;
          error = sht.measureHighPrecision(temp, humd);
          if (error)
              Serial.print("Error trying to execute measureHighPrecision(): ");
          else
              t = String(temp);
              h = String(humd);
          pressure = bmp.readPressure();
          p = String(pressure);
          Serial.print(t+","+h+","+p);
          String contentType = "text/plain";
          String postData    = String("ServerRoom,temp="+t+",humidity="+h);
          Serial.println(millis() - lastTime);
          if (millis() - lastTime > POST_INTERVAL) {
              lastTime = millis();
              Serial.println("making POST request");
              canvas.println("making POST request");
              delay(1000);
              error = client.post("/post", contentType, postData);
              if (error){
                Serial.print("error during POST:");
                Serial.println(error);
              canvas.print("Status code: ");
              canvas.println(statusCode);
              canvas.print("Response: ");
              canvas.println(response);
              Serial.println("Wait five seconds");
          delay(1000);
        FlooidOps @FlooidOps
        I think it may be because the I2C port uses GPIO 33 for SCL, and the Lan module also uses it for 'CS'. Can anyone comment on this?
          felmue @FlooidOps
          Hello @FlooidOps
          yes, that pretty sure is your issue. Have you tried to switch to the alternate GPIO for Ethernet CS, e.g. GPIO2 (instead of GPIO 33)?
            FlooidOps @felmue
            thanks @felmue,
            I made the change in the code which didnt work. Then I happened to glance over the docs page for the LAN module and spot that there is a little piece of plastic that you can move in order to change which pin the module is using!
            This probably isnt new to some of you but I cant see anywhere that details this feature other than this small image at the top of the page for the LAN module
            https://docs.m5stack.com/en/module/LAN Module 13.2
            I've successfully made a POST request with data from both sensors now, what a relief!
              felmue @FlooidOps
              Hello @FlooidOps
              I am glad to hear you figured it out. And sorry for not being more specific about how to switch to the alternate GPIO.
