IMU - what is the best vibration sensor
there are two IMU Units in the Shop:- https://shop.m5stack.com/products/6-dof-imu-pro-mini-unit-bmi270-bmm150-bmp280
- https://shop.m5stack.com/products/6-axis-imu-unitmpu6886
Which one is the best to anlayze vibrations?
Thank you
Ralf -
Please specify the vibrations you want to measure. There is a big difference between a mosquito landing on a concrete block and a earthquake that cracks the block. Both has to do with vibrations...
The best will be to open the datasheets (both are linked) and compare. As far as I see the range and sensitivity are more or less similar for both sensors.
