    IMU - what is the best vibration sensor
    Units
    1.5k
    • R
      RSchiessl
      there are two IMU Units in the Shop:
      1. https://shop.m5stack.com/products/6-dof-imu-pro-mini-unit-bmi270-bmm150-bmp280
      2. https://shop.m5stack.com/products/6-axis-imu-unitmpu6886
      Which one is the best to anlayze vibrations?
      Thank you
      Ralf
      • H
        holofloh
        Please specify the vibrations you want to measure. There is a big difference between a mosquito landing on a concrete block and a earthquake that cracks the block. Both has to do with vibrations...
        The best will be to open the datasheets (both are linked) and compare. As far as I see the range and sensitivity are more or less similar for both sensors.
