    M5Dial Rotary questions
    4 Posts 2 Posters 2.5k Views 1 Watching
      haeberle
      Dears
      Want to use the rotary wheel from the M5Dial in UIFlow, but it fails.
      I assumed the Rotary hardware ist needed.
      What I did so far is, I added the Rotary Hardware to my project as in the picture below.
      During execution I've got the error "AttributeError: 'Rotary' object has no attribute 'reset_rotary_value'". Looks the way I'm using ist is not the right one.
      Any ideas ?
      Kind regards
      • felmueF Online
        Hello @haeberle
        you are not doing anything wrong. The M5Dial UIFlow2 alpha-28 firmware has a typo for this two commands. In both cases value has been misspelled as vlaue.
        @M5Stack : please fix. See PR. Thank you.
        Try using below commands in an Execute code block instead.
          haeberle
          It works, thanks a million @felmue !
          • felmueF Online
            Hello @haeberle
            good news. My PR has been merged - the two blocks (reset/set) now work in UIFlow2 alpha-29.
