    M5 Stack autostart
    Core 2
    1.3k
    • O
      Obbiwannknobi
      Hello everyone, is it possible to start the M5Stack core2 automatically when you have pressed the reset switch? And how to import larger fonts ? Thank you very much
        As long as there is an active power supply it should auto power on.
        As to fonts, there is a memory issue with the core2 which meant that in uiflow1 and micropython a lot of fonts had to be removed as they took up needed space required to support units.
        UIFlow2 makes an attempt to fix this issue but isn't fully working yet.
