<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 Stack autostart]]></title><description><![CDATA[<p dir="auto">Hello everyone, is it possible to start the M5Stack core2 automatically when you have pressed the reset switch? And how to import larger fonts ? Thank you very much</p>
]]></description><link>https://community.m5stack.com/topic/5825/m5-stack-autostart</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 12:35:06 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/5825.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 19 Nov 2023 16:09:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5 Stack autostart on Sun, 19 Nov 2023 16:15:59 GMT]]></title><description><![CDATA[<p dir="auto">As long as there is an active power supply it should auto power on.<br />
As to fonts, there is a memory issue with the core2 which meant that in uiflow1 and micropython a lot of fonts had to be removed as they took up needed space required to support units.<br />
UIFlow2 makes an attempt to fix this issue but isn't fully working yet.</p>
]]></description><link>https://community.m5stack.com/post/22817</link><guid isPermaLink="true">https://community.m5stack.com/post/22817</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 19 Nov 2023 16:15:59 GMT</pubDate></item></channel></rss>
