M5Dial TFT_eSPI pinout
Does anyone know the correct pin assignment for the M5Dial SPI bus? I am trying to run LVGL with TFT_eSPI. I have tried the pin assignments I obtained from the M5Dial specifications page but I am having no luck. Here is what I have so far
// For ESP32 Dev board (only tested with GC9A01 display)
// The hardware SPI can be mapped to any pins#define TFT_MOSI 5 // In some display driver board, it might be written as "SDA" and so on.
#define TFT_SCLK 6
#define TFT_CS 7 // Chip select control pin
#define TFT_DC 4 // Data Command control pin
#define TFT_RST 8 // Reset pin (could connect to Arduino RESET pin)
#define TFT_BL 9 // LED back-light -
Have you added the GC9A01 driver?
@ajb2k3 said in M5Dial TFT_eSPI pinout:
GC9A01 driver
Hmm, no I did not. Let me do some research and try to find the driver
Can any one get this simple GC9A01 test to run on the M5Dial
My goal is to have LVGL running on the M5Dial so I am working my way through the display issues at this time.
This is the Micropython code I used to get a basic "Hello World" working.
import os, sys, io import M5 from M5 import * label0 = None def setup(): global label0 M5.begin() label0 = Widgets.Label("label", 50, 100, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18) label0.setCursor(x=50, y=100) label0.setText(str('Hello World')) label0.setVisible(True) def loop(): global label0 M5.update() if __name__ == '__main__': try: setup() while True: loop() except (Exception, KeyboardInterrupt) as e: try: from utility import print_error_msg print_error_msg(e) except ImportError: print("please update to latest firmware”)
@felmue, thanks very much, This worked perfectly.
@gordsh Hi ,
did you get this working ?
I am banging my head against the wall with this one right now ,
I am trying to use EEZ Studio with M5dial and using platform.io (or arduino ide whichever works)also if you have the file of user_setup.h for GC9A01. kindly share
Thank You -
@mukul_100_ Got this workking by using m5unified instead of tft_espi
But i can get the touch to work
as per what i read lvgl uses polling to get the touch coordinates using lv_timer_handler();but i dont understand how to implement M5Dial.Touch.getDetail(); to get the touch
