    I'm looking for someone who can walk me through my project. For $
    16 Posts 2 Posters 12.4k Views 1 Watching
    • I Offline
      IsoEek
      This is what I was able to do so far.
        ajb2k3 @IsoEek
        @isoeek Remove the loop inside the If/do as it not needed
        • I Offline
          IsoEek @ajb2k3
          @ajb2k3 LOL! Thank you. I completely missed that.
            What motor module are you using?
            I did some test of the earth unit last night and found out that if water raises above the black line, the unit will constantly read 1 in digital mode. Had some code issues with UIFlow last night and need to find my cap sensors
            • I Offline
              IsoEek @ajb2k3
              @ajb2k3 said in I'm looking for someone who can walk me through my project. For $:
              motor module
              No worries on the cap sensor. It works reliable with analog and a low threshold. I'm using a DC diaphragm water pump that I'll be running with a mosfet speed controller. Here is where I got to last night.
              I need to add a speed controller and a SSR relay...I feel like I'm forgetting something. Last night was not a good night for productivity nor thinking. Sorry.
                ajb2k3 @IsoEek
                @isoeek I know that feeling too well. Unfortunately the M5Stack SSR is not very powerful unless you get the ACSSR but you will still be limited on current
                • I Offline
                  IsoEek @ajb2k3
                  I'm sorry to hear you know the feeling. I have a few decent SSR lying around. I would have just bought the ACSSR if I would have known they existed. They are probably better than what I have and would have made integration easier. I'm only running 6A 120V AC, this is split to a 2A and 4A circuit. Thanks again for providing guidance and support as I figure this out.
                  Would you mind making a suggestion for resistors for M5stack. I keep seeing mention off them and know it will only be a matter of time before I need them, and I hate to not be prepared.
                    Suggesting a resistor is not as simple as it sound as it depends on the initial current draw of the device.
                    I blew the fuse in the SSR unit three times before I stopped to check the initial current draw. While the Heatplate (in my case) did use less then the SSR's nominal current, on initial power on, the heat plate would draw 3 times the current rating of the SSR's switch current rating!
                    Thankfully M5Stack placed a fuse on the the supply side to protect the SSR but I have yet to calculate what resistor I actually need for this scenario and hence the project went on hold.
                    You can read more about the issue with the project here: https://www.hackster.io/AJB2K3/m5stack-smd-heatplate-dd46b9
                    • I Offline
                      IsoEek @ajb2k3
                      @ajb2k3 Oh, I was afraid it would be in depth. Thank you, I'll read through it.
                      • I Offline
                        IsoEek @IsoEek
