    Error compiling examples
    FAQS
    compilation dirent.h
    9.6k
    • C
      ChristianS
      Hello everyone,
      First time on M5, and quite enthousiastic.
      Unfortunately, I am unable to compile examples under macOS 10.11.6, Arduino IDE 1.6.6
      I followed setup instructions here: https://m5stack.github.io/m5-docs/#/en/quick_start/m5core/m5stack_core_get_started_Arduino_MacOS?id=step1-install-arduino-ide
      but fixed library path according to a message posted on the forum: https://dl.espressif.com/dl/package_esp32_index.json
      Then, I tried to compile (or compile & upload) "Hello World": here is the message I get:
      WARNING: Spurious .git folder in 'M5Stack' library
      Build options changed, rebuilding all
      In file included from /Users/simon/Documents/Arduino/hardware/espressif/esp32/tools/xtensa-esp32-elf/xtensa-esp32-elf/include/dirent.h:6:0,
      from /Users/simon/Documents/Arduino/hardware/espressif/esp32/libraries/FS/src/vfs_api.h:24,
      from /Users/simon/Documents/Arduino/hardware/espressif/esp32/libraries/FS/src/vfs_api.cpp:15:
      /Users/simon/Documents/Arduino/hardware/espressif/esp32/tools/xtensa-esp32-elf/xtensa-esp32-elf/include/sys/dirent.h:10:2: error: #error "<dirent.h> not supported"
      exit status 1
      Error compiling.
      Any suggestion ?
      • C
        ChristianS @ChristianS
        @christians After Arduino IDE update to 1.8.7, cleaning libs, re-installing, everything works well.
        • lukasmaximusL
          I was just about to suggest you update Arduino but you already figured it out. Any other issues you bump into let us know
