    How to use SPI with the stack ??
    5 Posts 3 Posters 15.0k Views 2 Watching
      moelski
      Hi guys,
      today I spent some time getting my MCP3204 working. It´s a 4 channel ADC with an SPI Bus.
      I connected the MCP like this:
      #define SPI1_CLK  18  // D -> Clk   -> Pin 11
      #define SPI1_MISO 19  // Q -> D Out -> Pin 10
      #define SPI1_MOSI 23  //   -> D In  -> Pin  9
      #define SPI1_SS   16 //    -> CS    -> Pin  8
      It´s working as expected as far as I don´t use any display stuff from the M5 Stack.
      As soon as I ad the following to my code:
       M5.begin(); // true, false, false);
       M5.Lcd.printf("TEST");
      things getting wired. The readings of my MCP3204 are wrong.
      I convert the AD values to temperature vales since I use some BBQ sensors. And the results are about 2 degrees wrong when adding the M5 Display.
      Example: Reading temp without Display -> ~21° and with display ~23° or sometime ~17°
      I can do some addition checks with the plain AD values to get a better understanding.
      But anyway ... What´s wrong in using the SPI bus for a second device?
      Are there any drawbacks i don´t know? Any issues?
      Maybe someone has some explanation for this topic.
      Dominik
        moelski
        Hi Guys,
        I think I figured out the main problem.
        It has nothing todo with the SPI bus ... It´s the 3,3V line.
        Take a look at the picture. If you set the LCD to 80 (~33%) brightness then the PWM signal is extremly present on the 3,3v line ... And the MCP3204 don´t like that :-)
        And this is a picture with 255 (100% on) brightness ...
        No further explanation needed ...
        Dominik
        RopR 1 Reply Last reply Reply Quote 2
        • KabronK Offline
          Kabron
          Thanks, it's useful.
          • RopR Offline
            Rop @moelski
            @moelski Have you tried adding a small capacitor to ground?
              moelski
              Hi Rob.
              Yes there are 100nF directly at the Power supply of the Mcp3204.
              But that won't help. I Ordered some lm4040 to have a clean voltage reference.
              I think that will help.
              Regards
              Dominik
