    ATOM DTU NB MQTT Example dosn't work
    5 Posts 2 Posters 4.3k Views
    • B Offline
      BennoB
      Hello Community,
      i have an ATOM DTU NB iot device and i try the example flow in UIFlow Base - DTU - NB-iot - Load Example. I changed the mqtt-Server and credentials but i get an error.
      Serial Output:
      "rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
      configsip: 188777542, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff0018,len:4
      load:0x3fff001c,len:5228
      load:0x40078000,len:12908
      ho 0 tail 12 room 4
      load:0x40080400,len:3512
      entry 0x4008063c
         _  __ _
      _ ()/ | | _____ __
      | |/ _ \ \ /\ / /
      | || | | | | () \ V V /
      _
      ,||| ||___/ _/_/
      APIKEY: XXXXXXXX
      File "main.py", line 36, in <module>
      File "base/DTU_NB.py", line 50, in mqtt_to_connect
      File "base/DTU_NB.py", line 75, in mqtt_ischeck_connect
      IndexError: list index out of range
      MicroPython f78d1e78a-dirty on 2022-11-24; M5Stack with ESP32
      SIM is inserted. What i'm doing wrong? Can somebody help?
      • felmueF Online
        Hello @BennoB
        have you tried to run the example without modification, e.g. connecting to mqtt.m5stack.com as a test? Does that work?
        • B Offline
          BennoB
          The same. Nothing changed. Load example, Download to device, open Terminal and reset device with button B.
          ho 0 tail 12 room 4
          entry 0x4008063c
             _  __ _
          _ ()/ | | _____ __
          | |/ _ \ \ /\ / /
          | || | | | | () \ V V /
          _
          ,||| ||___/ _/_/
          APIKEY: XXXXXXXX
          • B Offline
            BennoB
            Same issue with downgraded V1.9.9
            • felmueF Online
              Hello @BennoB
              I can confirm that the UiFlow example doesn't work for me either. The block to connect to MQTT seems to be broken or not properly adapted for the SIM7020.
              @m5stack : please fix. Thank you.
