lcd.arc green outline
Hi ,
when I use lcd.arc graphic I always have a green outline that appears. is this normal? how to avoid that?
Best regards Bertrand -
Hello @Ber
it looks like using the arc block only one color (either outline or filling) can be defined at the time. The color which is not defined seems to be random, causing the unwanted outline.
So instead of using the arc block directly you could use the
Advanced
-Execute code
block which then allows to define both colors together like this:lcd.arc(120, 160, 100, 50, 0, 90, color=0xff0000, fillcolor=0xff0000)
